Tires choice Continental vs Michelin
#51
Super Moderator
1) High levels of castor applied for straight line stability & self centering action
2) Reduced turning radius
3) Under lateral loading, the centripetal force will cause more of the tyre's surface to be in contact with the road. (contact patch)
#52
W204 2012 C250 CDI
There are a number of reasons Benz steering geometry does this.
#53
2012 c, 2014 c, 2013 E, 2014 ML BT, 2016 E, 2016 GLE, 2017 S550(current), 2020 GLE450(current)
my 2012 had michelin 225f/245r
my 2014 has conti 225f/255r
miche rides little harder than conti
miche has less traction on wet than conti
after 22k miles, miche looked like new....conti has 400mi so i dont know yet
conti ++ DWS is +++
conti ++ DWS is +++
#54
Super Moderator
It is impossible for a Conti SC to have a softer ride than a Michelin PS all things such as pressure remaining equal.
Which Conti vs. which Michelin.
#55
How would you say the DW or DWS are on the W204? I chose PSS for my brother's tuned 335 because of the grip, feel and performance, but I chose the DW for my C300 for the comfort, and treadlife. They are both amazing tires from what I've read and actual grip isn't much different.
How about DWS vs A/S 3?
I'm about to replace my conti procontact 3's with a set of DWS.
My first W204 C300 came with the all season Continental ContiProContacts they were quit and comfortable i'll give them that much. So when it came time to replace them I wanted something sportier to go with my sport sedan, plus I live in Sunny South Florida, so all season tires aren't a necessity. I did my research(was on a budget) and replaced them with the ExtremeContact DWs they were ok at first, better grip etc., over the OE CPCs but they wore rapidly and IMO didn't offer that much more performance(not as dramatic as i hoped) over the worn(coin test) OE ContiProContacts.
I should've went with the Michelin PSSs, my brother did on his W204 C300 at the same time I mounted the DWs and I was blown away.. talk about a dramatic difference totally changed the dynamics of his car just as comfortable as the CPCs but with amazing grip! I easily took highway on ramps at 10/15mph faster and great grip in the rain and his brakes felt stronger(like he swapped in performance pads etc.) I can go on on.. night and day difference!
My 2nd W204 C250 came equipped with Pirelli P Zero Nero All Season tires and they out perform the ContiProContacts and ExtremeContact DWs in ride comfort and grip.. they're really nice and above average OE tires IMO!
My other brother just had some Pilot Sport A/S 3s mounted on his W212 E350 and all have to say is WoW! Just as sticky and comfortable as the PSSs! but with all season versatility!
So when it comes time to replace my OE Pirellis i'm going with the Michelin PSSs or with whatever max performance tires Michelin brings to market at the time!
Cheers,
p.s. all the above sedans are sport models.
#57
Ok, i'll try to be as objective as possible.
Cheers,
Cheers,
I appreciate your input and advice. (Unfortunately?) I already replaced the front tires with DW this past fall since they were getting low and I didn't want to risk losing traction. Now my rears are getting low and I want something that would last long in the rears since I am such a spirited driver. So I opted for DW in front and possible DWS or DW on rears. I picked front DW because imo, the w204 is a mess of sport and comfort, without truly doing either one well. AND because the C300 doesn't have the power to truly break grip with all seasons. From what I had read, the DW had softer sidewalls, so less response but softer ride. I wanted a mixed compromise tire, just how I felt the C300 already is as a car. From all the responses here and from further reading online, I probably should've gone mich PSS, just like I did for my brother. He's pushing 400 whp though, and I'm doing 185 if I'm lucky. I guess I'll stick with my mistake, and just get a set of DW or DWS for the rear since I live in Cali and there is no snow. In a couple years, maybe I'll get the chance to try the PSS, but they're pretty expensive.
#58
Super Moderator
#59
It's taken a while but I will give an update of the CSC5 on my sl600 Carlsson 1/10Ultralights front 255/30r20 rear 305/25r20. I have done a couple of thousand miles of fast driving. The road noise is noticeable with the top down but doesn't transfer to the cabin with the top up. The grip is very good on the road and the comfort has not changed from the stock 18" wheels and tyres(this was very surprising). I only managed 3 laps around SPA F1 as my brakes got lunched but I was very impressed with the turn in grip and feel of the tyres. They did show some rolling of the outer edges after the 3 laps however I think my pressures would have gone a little high as I didn't reduce them prior to setting off. I have ordered some PSS to put on for when I return to SPA in September(along with Brembos BBK all around) so I will be able to give a comparison then.
#60
W204 2012 C250 CDI
#64
Just went through shopping for tires (2007 ML 350). It had Continental Positive Contacts that went almost 65,000 miles. I went with the Michelin Latitude HP because I liked the brand and used them before. Research also showed they were also original equipment on the ML.
Michelin has served me very well on my Durango, Jetta, and MBZ 190. I've found BF Goodrich to be a nice riding and wearing replacement on another 190, a Pontiac Grand AM I owned and daughter's BMW 325i.
Best advice is to be an educated shopper and buy from a place that is nearby if possible to take advantage of free repair, rotation/balance. In the case of Costco where I bought mine, it included free nitrogen fills.
Set of four out the door was $886 which included the $70 rebate. Talked to Discount, NTB, Sams and Costco, compared prices and brand choices both in person and online.
I've dealt with all of them at one time or another but this time Costco seemed like the best all around deal. The Latitude HPs were in stock, but not shown online, so a trip out there in person got me the exact tire I wanted. After the first rotation now and we're very happy with the set so far with about 10,000 miles on them.
#65
W204 2012 C250 CDI
#66
BIG TIME!!!
Yes. Nitrogen is worth the money. 1. It helps with prolonging tire rot (keeps moisture out). 2. Tires are naturally porous and the molecules of nitrogen are larger compared to just air which keeps your tires at a constant pressure. 3. Also being that it keeps them at a constant pressure it helps with wearing of tires evenly and also help with fuel economy.
#67
I agree with JPc300, and also did extensive reading on the subject and also spoke with some tire representatives. I concluded if the initial cost is not too much, it is worth trying and seeing if it does make a difference.
Not sure if I would have bought the nitrogen but it is included in every tire purchase at the vendor (Costco in the US). Also, when I take it back for the free balance/rotation, they add more as needed.
We may be splitting hairs here comparing the two, but overall if you keep a close eye on maintaining the proper tire pressure and keep the set rotated and balanced, you probably won't notice any difference.
Since this is the only vehicle I've used nitrogen in, I'm keeping track to see if there is any noticeable difference.
#68
IMO it all really boils down to if the cost Vs the hassle of keeping up on your tire pressure. Also Average cost of filling with nitrogen is about $10 Per tire. At 40 bucks it's just worth the savings in fuel per year. You prolong the life of your tires and you don't need to worry about checking your tire pressure every so often. It pays for itself.
#69
2013 C250 Sport P1
#70
W204 2012 C250 CDI
BIG TIME!!!
#71
1 Post
'08 C300 4Matic Sport, '02 530i
Nitrogen in street tires is one big scam. Sure, there may be some miniscule benefits, but the primary benefit is someone getting extra money from your wallet.
Here is a long time tire industry veteran's quick summary on this:
http://www.barrystiretech.com/nitrogeninflation.html
#72
Have you ever heard of "don't believe everything you see online". well this is one of them!!
#73
1 Post
The guy that wrote the summary I linked to is a well respected professional and I know his credentials. I have no reason to believe he's wrong. On the other hand, I have no reason to believe you, especially that you haven't posted any evidence to confirm your statements.
#74
Yup. I am applying this notion to everything you wrote in this thread.
LOL! That's Ok. You're entitled to believe what you wish to believe. I work in the automotive business and have been doing it for 18 years. I have no need to prove anything to you. I just add my input and whom ever feels they want to apply it, good for them otherwise, like i said before your entitled to believe what you wish.
This is as much as I will amuse you.
