Day Running Lights/head lights
hi guys just wondering why my day running lights DRL it's on together with head lights in days time? It should be only DRL on in Auto mode. I already putting in cluster whereby the mode for day running lights its enable.still it come out together with head lights. I just to on the DRL on day time not the head lights too.Any advices from you guys? Or else anyone has the value code for day running lights in Xentry /Star that I can diagnostic. I have w204 C200 sedan 2011.
2014 C300 4MATIC
if the conditions are dark enough, your headlights will turn on while in Auto. If it's completely sunny and they still turn on, the light sensor is probably having issues/dirty
I had my lights reprogrammed to turn off everything including day time running lights when it is at the "O" position then when at "A" everything is automatic BUT DRL is still off. My car is a canadian version that drls are always on no matter what and the xenons are marking the lens so after dealer replaced the headlights I ask them to turn the damn drls off as the light sensor on the car is so sensitive that slight dim of the sun will turn on the headlamps.
