2012 C250 USB dongle in the glove box?
2014 Mercedes-Benz ML350 4-MATIC | 2007 CLK350
Can someone tell me what the USB dongle in the glove box of my 2012 C250 is for? Doesn't seem to be anything in the manual about it. I should note that the car has a universal media interface Apple 30 pin connector in the console so not sure it's for that. It also has factor Bluetooth so I doubt if it's for that either.
Maybe something to do with NAV or adding Nav? BTW, the car does not have Nav.
Thanks.
Thanks.
1 Post
2013 Mercedes-Benz C250, Iridium Silver Metallic; 2001 Mercedes-Benz C240, Brilliant Silver Metallic
Do you have a US market car?
Thanks.
Thanks.
2012 Mercedes C250
Interesting. My 2012 C250 (no nav, no HK) does not have a USB plug in the glovebox, although it does have one in the center console- along with the 30-pin connector. I was given a pigtail to plug into that which includes an iPod plug and an aux plug. Unfortunately, I cannot play my iPods using any of the three methods. The car says there's either nothing there, or 'device incompatible'. Since I can stream music from my iPhone via Bluetooth, it isn't really a problem, but it does bother me a bit.
2012 Mercedes C250
OP- try plugging an iPod into that USB. AFAIK, even a few-year-old iPod should play and charge through that cable. Many cars hide them in the glove box if you don't need to access the iPod regularly- for instance, if the car controls it.
That cable is part of the media interface option of the car. There are different bunch of cables that can be swapped with it. The USB connection can let you plug-in a mass storage devise like a thumb drive with MP3 songs on it and play it on your command or audio 20 like a ipod.
UPDATE: re: 2012 C250 USB dongle in the glove box?
I tried hooking up several USB devices: USB stick with MP3s, multiple iPods (old and new) as well as a couple of different iPhones and a Galaxy S5. Nothing works or shows up under "Aux" or "USB Storage" at all. The phones do say that the source plugged into it is not recognized. If you dismiss that warning the device will actually charge -- although not that quickly. More like a slow trickle charge. So there is power going through this cable, just no data connection apparently. At least in my case.
What I find interesting is... if there is already a media interface connection in the consul (in my case 32 pin iPod connection) then why the USB dongle in the glovebox?
Further adding to the mystery, why does my car have an auxiliary (Aux) and "USB Storage" listed under audio if the only USB connection doesn't work (assuming they're related)?
So far I can't tell what this is for. Love for somebody to solve this mystery.
Yeah i tried the same. I also have a USB port in the center console and I currently have a USB flash drive inserted with music and it works well, I tried plugin in the same flash drive into the USB port in the glove and it dose not work.
