Aftermarket Amp Install
Old 09-04-2015, 04:00 PM
swagger_jacker's Avatar
'13 Infiniti G37
Has anyone had/done and aftermarket amp in their MB? Looking to add a sub in the truck and was wondering where they may have tapped into the speaker wires and everything, and also what the setup looks like.
Old 07-20-2016, 03:59 PM
Jeffrey Henke's Avatar
2006 C280 4MATIC (W203)
I had no problems installing 2 amps in my '06 W203.
I tapped into the bottom fuse in the fuse box in the trunk for the remote signal wire because it is only hot when the key is turned in the ignition.
I ran power wires from the battery, across the engine bay, to a firewall on the driver's side, and under trim into the trunk where I have both amps.
I grounded on the frame of the car in the trunk, specifically on the top of the opening from the rear bench to the trunk. Just be sure to remove surface paint if there is any so that you have a quality ground connection.
Old 07-20-2016, 07:20 PM
karan538's Avatar
W205 AMG prem+ (waiting delivery)
Had a amp install in my w205, speaker wire was tapped into the front left subwoofer in the footwell.
Old 07-20-2016, 11:02 PM
Mike5215's Avatar
2016 C300
Www.w205audio20.wordpress.com has a write up and DIY for a DSP amp install in a base system.
Www.w205audio.wordpress.com has a write up on my Audison/Focal upgrade on a Burmester car.
Old 08-09-2016, 01:56 AM
janusgrimnitz's Avatar
C200 4matic
I have 2 amps in my C200 as well
Old 08-13-2016, 08:35 AM
Mancub92's Avatar
2000 s500
Amp
That c200 is different from a s430 lol
Our battery is in the back and if you wanted to do the big 3 you would need more power cable to run from your alt to the battery
Quick Reply: Aftermarket Amp Install
