Does blue top solenoid fits C32's?
Old 03-21-2011, 04:23 PM
Robert AMG's Avatar
Cls63 & C32
Can someone confirm if the the blue top solenoids that the E55 guys are using (upgrading) in their tranny fits our C32's tranny?
Thanks.
Old 03-21-2011, 04:37 PM
Newzchspy's Avatar
PLAID
Blue Tops
Thanks.
I dont think they do and it also depends on the trans serical #. One guy tried them on a C32 and said they did NOT work!! See this:
Thread resurrection below:
I have a pair of blue top solenoid valves if someone is interested. Tried them in my C32 but unfortunately, the valves didn't work. $250 shipped. (note this is 2 year old thread I do NOT have these for sale)
The C55/E55 guys swear by them (Mike aka Hooley did his) and so did several others. Gotta change oil and drop whole pan BUT they say it works for C55?? I dunno know about the C32??
Old 03-21-2011, 06:03 PM
1stmeez's Avatar
2002 C32 AMG
why blue
what do these solenoids do that the standard ones don't?
Old 03-21-2011, 11:46 PM
ruben65's Avatar
The valve opening is larger in the blue top so it can push more fluid quickly. Basically faster and firmer shifts.
However from the general concensus of people that have done it is that it makes the car shift hard, almost like an old school shift kit, might not be comfortable for a daily driver.
Also from what I found out from research and my local parts dealer is that these are also use in the Maybach transmission.
Also to answer the question I do not believe it works for the C32 as it has as specific serial number they started it.
If I recall the deadline number that was given was trans 722.643.xxxxxx after that should have Blue tops as standard. You would need to get a data card for your card to tell your transmission serial #
Do a search there is a thread here that tells the deadline for the transmission and years etc...
Attached Thumbnails Does blue top solenoid fits C32's?-browntopopening.jpg   Does blue top solenoid fits C32's?-bluetopopening.jpg
Old 03-24-2011, 11:54 PM
RES
RES's Avatar
2005 C55, 1988 260E, 2000 Chevrolet Silverado
I changed mine and it is very firm in S mode. But its not bad in C mode once the transmission adjusts to them.
Old 03-25-2011, 12:41 AM
mikekuriger's Avatar
2010 C63
anyone in SOCAL have blue tops in their c55? I'd like to go for a ride!~
Old 03-25-2011, 01:28 PM
newbenz2's Avatar
86 16v turbo, 02 c32
What about modifying the stock c32 solenoids with a counter-bore like the blue tops have? If someone has a spare set they don't need I can use my car as a Guinea pig.... I can machine these no problem...
Old 03-25-2011, 02:27 PM
2010 C63
that might work better actually.
Old 03-25-2011, 02:35 PM
newbenz2's Avatar
That is assuming the counter-bore and countersink is the only change. I wonder what the difference in the solenoids are.. Also we can machine different sizes for people that want softer or harder shifts...
Old 03-25-2011, 05:18 PM
2010 C63
i was thinking that the TCU was able to control that, and that on the C55 it's already maxxed out. So adding the blue tops and lowering the pressure in the TCU programming may work well.
Old 03-25-2011, 06:28 PM
Former Vendor of MBWorld
MBH motorsports's Avatar
C63, SL55, E55, CLS55, ML63, C55
They do fit the C55 and they do make shifting more firm... However down shifting (for me) seems a little out of sequence. When I would brake for a red light,it felt like the trans was over powering the brakes a bit. I found, with my slipping trans that these acted like a "Band Aid." Fixing the up shifts slippage form gear to gear. After a while my trans was shot and I needed a new set of clutch packs.
Since the c32 has a 722 . something trans. I would think they would fit and possibly help. Thats if you can live with the jerky down ****s. The best way to describe the down shifts when braking, is like you accidentally down shifted your car when you didn't want too. My old lady hated the way the car shifted, I told here it was no worse than the way she drives here manual trans nissan.
Old 03-25-2011, 09:42 PM
2010 C63
yea a tcu reprogram could fix the downshift issue, or just use neutral when the wife is in the car
Old 03-25-2011, 11:28 PM
We need to make one thing clear... she's not my wife! LOL I did use the neutral trick, Funny you say that.
Old 03-25-2011, 11:40 PM
2010 C63
oops sorry about that. by the way, the drag radials worked well. the only issue is they don't fit with the stock lug bolts. For that day, I just used a few washers to take up the slack but in the future I'll be getting some real lugs installed or get some shorter stock lugs.
thanks!
Old 03-26-2011, 07:04 AM
PTE
PTE's Avatar
05 ML-500 , 03 CLK5.5 AMG has left the Garage
I've installed these on a good trans< . The down shift coming to a stop might be a little abrupt. in Sport mode , But if you are just cruising with friends on a dinner date thing ,or worried it may cause some comments, then use the Comfort trans mode. Cheers _PTEngineering
Old 03-27-2011, 01:44 AM
ali saklaoui's Avatar
C32AMG.335 e92 fbo.protomotive996 gt2
Thanks.
I installed them on the supercharged W208 CLK430 1 year ago,they are working well,he purchased them from Dubai $420 both.
Old 10-22-2014, 12:12 PM
Pansu's Avatar
"World fastest" C32 AMG
Old topic, BUT can anyone confirm these blue tops work in C32?
Old 10-23-2014, 06:06 AM
macbryanie's Avatar
Porsche 2004 911
I think Robert AMG did it.
Pls post a threat on your car. Its amazing and not given its due credit.
Old 10-25-2014, 05:51 AM
Pansu's Avatar
Maybe Robert is dead, becouse no answer to my messages
Old 10-27-2014, 03:45 AM
Robert AMG's Avatar
Cls63 & C32
Hehe, still alive, the blue top solenoids fit perfectly. it works and make the shifts harder, but don't ask for the tcu that raise the rpm, if u raised the rpm u will get a delay between shift before it shifts, the blue tops help after it shift not before.
install the blue tops and ask Jerry for ecu/tcu that has stock rpm(6200 limiter).
Old 06-20-2015, 05:15 PM
enrikerace's Avatar
WHITE E320 1999, GruppeM Intk, E55 TB, Evosport Pulleys, Longtube Cer. Coat Headers, Cat/res Delete
Sorry for bringing this thread back to life.
Everyone complains about the hard downshifting of the car using the blue solenoids.
I was looking around and saw a video about a 722.6 transmission teardown. The guy mentions that, in this video the brown top solenoids, are for fluid pressure. One (trans plug side) is for modulating pressure and the other one is for shifting pressure.
I am thinking of making tests, using the blue top solenoids with the brown top ones combined, in order to look for fast shifting with controled smooth downshifts.
Any thoughts?
Quick Reply: Does blue top solenoid fits C32's?
