PLEASE...Can some one snap an easy picture and share it? Rear Seat Question...
Hi,
Can someone please post an image of the way the intermediate (long skinny section between main sections where the seatbelt buckles are located) pad is mounted OEM in your ///AMG? I want to get this install as close to OEM as possible and neither WIS or EPC show me…I can not even buy the nut/or bolt to hold it down!...it's not shown!!!
Of particular interest, and what I am trying to accomplish is routing and installing the vacuum hose from the driver's side...to some "T" and then over to the 1/3 seat section on the passenger side.
This would be a BIG help to me to get it as close to OEM as possible...thank you!
Thanks!
Jake
Thanks!
Jake
Never mind...although if you want to add a picture - it may help someone else!
Thing is...WIS tells you to remove the screw on the intermediate pad. EPC tells you there is a push button for the rear seat...all you need to do is press this "push tab" cylinder onto the standing studs, it clips to the threads...no tool needed, no steel part to turn...only conflicting information on the MB systems...
I retrofitted Folding Seats last night...and did my best to route the vacuum line out of the way of the seats, LATCH and under the intermediate pad...after the carpeted dressing went in...it's all good.
Talking to myself now...
Installed/retro fitted.
https://mbworld.org/forums/c-class-w...-thread-6.html
