Headlight HID
Old 07-31-2014, 06:42 PM
TylerF's Avatar
C32 AMG
Headlight HID
It could just be me, but I have never had a problem with changing a light bulb before on any car.
I place the new hid bulb into the light, screw on the back locking plate, then plug the socket onto the light.
Two days later my light is dead again. The light moves up and down with the bumps on the road...
Is the light bulb suppose to lock onto the locking plate first before locking it onto the back of the headlight?
Old 07-31-2014, 06:49 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
The C55 has a locking spring clip that holds it in - not sure if it's the same on the C32.
Old 07-31-2014, 09:03 PM
TylerF's Avatar
C32 AMG
What does that clip look like? I can't find anything online
Old 07-31-2014, 09:30 PM
Viper98912's Avatar
Check out the back of this projector, it's a U-shaped clip with two ears on it; looks like a paper clip
http://www.theretrofitsource.com/med...ojectors-2.jpg
Old 07-31-2014, 10:12 PM
TylerF's Avatar
C32 AMG
I could be wrong but I don't think I have that clip....
If I am missing the clip where can I pick one up?
Old 08-01-2014, 06:48 PM
Supgee's Avatar
2003 C32 AMG
C32 doesn't have the spring clip style for the HID's. It's a black plastic twist-lock type device. You put the bulb into the twist lock and then stick the bulb into the headlamp and then turn the little sleeve and it locks into position. If you look carefully on the locking device it says "TOP" indicating which way to position it. Good luck, its kind of a pain in the *** to do.
Old 08-02-2014, 02:24 PM
TylerF's Avatar
C32 AMG
Is their some kind of guide with photos online?
Old 08-02-2014, 11:16 PM
EDgineered's Avatar
2005 C55 black on black aka DVS C55, 2007 C230 sport silver on black for the boss
Look at the back of the other light unless they are both messed up.
Most name brand auto parts stores install bulbs for free.
Make sure to not touch the bulb, it will cause it to go bad.
Old 08-03-2014, 10:31 AM
TylerF's Avatar
C32 AMG
Yeah I know all that about the bulbs.
Other light is fine I'll give it a look.
Last thing, should I disconnect the battery?
Old 08-04-2014, 01:16 PM
C230 Mulac's Avatar
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
Just thought I'd throw it out there, but maybe you could have a bad ballast and it's causing a short and burning out the bulb? Not an expert so don't quote me on this, just thinking out loud...
Old 08-04-2014, 06:11 PM
TylerF's Avatar
C32 AMG
Bulb was super lose because it wasn't clipped in... I was able to move it up and down with my hand even when the back screw lock was on. It most probably hit on the inside of the headlight
Old 08-09-2014, 04:09 PM
TylerF's Avatar
C32 AMG
Which wire is the positive and which wire is the negative? I have a replica adapter that I will splice to replace my burnt plug.
Quick Reply: Headlight HID
