A handy tool for your pad replacment
Old 10-08-2015, 06:42 PM
Former Vendor of MBWorld
RacingBrake's Avatar
CLS550
If your car comes with Brembo calipers and track often I believe you are aware of how awkward it can be when it comes to changing your brake pads by removing the pin out and put it back after the pad is replaced.
We are introducing a new handy tool to end your frustration, so you can change your brake pads quickly w/o damaging your calipers. The following pictures should be self-explanatory.
The punch:
End view:
Punch out:
Punch in:
These pictures are taken on the bench, you will appreciate its convenience even more when you replace the pads in a caliper attached to the spindle/upright.
This tool will make your switching/replacing the pad easy with more confidence w/o struggling to remove the pin, so you would always use the right pad with proper compound between track and street.
Click here to purchase
Quick Reply: A handy tool for your pad replacment
