Suspension DIY/spring compr. rental?
So, I just took the plunge and ordered the full euro spring/pad set with Koni adjustables for my C43.
It looks pretty straightforward, but is there anything I need to watch for specifically that could be problematic?
And is anyone willing to lend/rent out a spring compressor tool? I'll pay a deposit or whatever you need to make sure you get it back.
Jason
Jason
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
You need the right tool (Klann type compressor) otherwise you could loose a limb and even using the right one it remains dangerous. I know cause I nearly broke my thumb when the cup slipped off the spring. The spring shot away about 10 meters without hitting anything
Check here:
https://mbworld.org/forums/5172035-post29.html
https://mbworld.org/forums/5189228-post45.html
Check here:
Oh yeah, I'm very aware of the dangers of doing this, and want to make sure I get the cup/disc type compressor vs the fork "U" type.
Ah, yeah, you have the style I need. Do you rent it out by chance?
DRB is in Switzerland, with the shipping it might be cheaper to go buy one...
Here you can buy a Klann clone:
http://www.zdmak.com/wbstore/main.as...CTMP=1&LowCt=0
C63 507 AMG DA Car #19
I just upgraded my clk55 front struts/springs. I used a harbor freight clam-shell macphereson strut spring compressor. Very easy to use.
And these springs are no where near as knarly to deal with as the old domestics from the 80's.... with unsprung L of 2-3'.....!!!!!!! that was sketchy.
Just take your time and follow instructions..... OR you can just bring the macphereson strut/spring assy to your local tire shop and they will pull apart for you. GL.
1995 C36 AMG, 1998 C43 AMG
I think I'm just going to have the shop do the suspension when they do the control arm bushings. They have pretty great rates, and it'll cost about 350-400 for the whole job.
This way I can keep focused on detailing the paint still.
too bad you're up in OR otherwise i could have helped you at my shop in north hollywood... i have all the tools for mercedes including the one to do the control arm bushings...
fredtga, ugh, that sucks. how hard is the job really? how dangerous for both suspension and bushings?
Would you rent the tools out for a deposit?
Cheers
nkctb7, that's pretty close, would you mind checking shipping to 97210? Even if it's a bit pricey, likely still less than buying one or paying labor to have it done. Do you have the U shaped kind or the O disc shaped kind? I'd prefer the disc shaped as it looks safer.
Was under the car looking at everything yesterday, and luckily it all looks pretty straightforward.
Any chance you have the bushing press as well? =)
Cheers
Do you still have a shop in North Hollywood?
Thank you in advance,
-Tom
