Throttle body wiring help
Hey guys. My SDS is down at the moment or I else I would look there. Can someone tell me the wiring diagram for the throttle body to the ECU? There are 6 wires and I need to know where (which pins) the following wires connect to the ECU:
MOTOR +
UIP POTI +
IPM POTI -
MOTOR -
IP2S POTI 2
IP1S POTI 1
99 C43
TIA
MOTOR +
UIP POTI +
IPM POTI -
MOTOR -
IP2S POTI 2
IP1S POTI 1
99 C43
TIA
00 C200 & 00 C55 & 06 SLK55
The newer should be "square" one,,
it can't be done to go from round to square, need to replace many items for that, which i believe NOT worth it..!!
ZAYED,,
ZAYED,,
Newer square plug is fully controlled by ECU/ME2.8, but the round plug is semi-AKA controlled by ECU/ME2.0,,
you have to change the Engine harness and change or re-file the ECU to the newer version with start-up DAS authorization system..!!
ZAYED,,
ZAYED,,
