Wudd this AMG deckel fit ontop of our engines?
i wunder if the 113986 AMG engine cover fits our 4.3/5.5 engines without any fitting modifications?
the stock AMG engine cover with rear airfilter compartment looks somehow cheap and dull to me!
i would like to fit a nicer looking engine cover from w220 S55AMG.
wudd C43 airfilter/airmass sensor fit the 113986 airfilter/airmass sensor compartment?
wudd C43 2x side air hoses be long enuff to connect to this 113986 engine cover?
thanks
thanks
00 C200 & 00 C55 & 06 SLK55
It will fit Dennis, but you may need to relocate or little bit bend fuel hose, and it may touch the A/C main hose, which easy to move it little bit far..!
C43 air box tubes got a differ shape(from the end, that attached to the airbox), and they cannot be used in any other M113 air boxes..!!,
you can cut your stock tubes, then joined them with 3" air duct, to that S55 air box..
ZAYED,,
ZAYED,,
ZAYED,,
ZAYED,,
it seems to be too much of a work to do this mod.
if i have to cut and bend stuff, i won't do this.
just wanted some info if it was an easy job?
thanks anyway
No Dennis, it's soo simple,
any M112/M113 air box can be interchangeable to each other, the main difference in Engine bay on each specific chassis,,
i tried many M112/M113 in "C43/W208 CLK55/W210 E55/R129 SL500", their air boxes fit to each other, just simple work will make it fit properly..!
ZAYED,,
ZAYED,,
these covers sits on V6 engine?
Dennis don't like them very much , they don't look dat good to Dennis
this is the cover you refer to, am i riight?
it's not so nicely designed.
i don't fancy it
http://www.ebay.de/itm/Mercedes-W210...IAAOSwd0BVvMCs
i don't fancy it
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
stock box sits ontop the engine absorbing lots of heat into the engine.
the newer 55K setup sits on both sides, this must give more cold airflow and probably some better performance?
Good input Dennis,
Honestly; i didn't dyno the car, but as you said; these 2 boxes are actually
running against the side of the manifold which would appear to be more effective that will feeding cooler air,,
but stock airbox or even RENNtech airbox is sit right over the top of the intake manifold (which get very hot, so imagine where that heat is going)...!!
ZAYED,,
ZAYED,,
good info with all the pictures!
perhaps i should have added this box also to gain the extra 6hp to get to 400hp sharp.
