C43 with 55 swap quest for 12's
1999 C43 AMG, 2005 E55 Wagon
with a 3.46 diff a 55 swapped C43 could blow away TONS of modern cars
DRBC43AMG (05-11-2016)
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Yeah and it has been tried several times, but never heard someone getting everything to talk the same digital language If someone has really succeeded, then it must be in a very very hush hush environment I guess everyone on here would like to hear some more
Received 3,353 Likes
2012 CLS63
sharp ride
Try cutting out the "fins" on the airbox and using AFE Pro Dry filters or K&N. This might help with the airflow and get better oxygen to the engine hence might improve on your time.
#34
In drag racing its all about your 60'. If you're trying to squeak everything out of the car at the strip your efforts are futile if you don't have dead hook off the line. Get slicks and you'll run 12's.
#35
So my C43 has developed a misfire on cylinder 6 but it only misfires at 6k+ RPMs in 3rd gear(under high load). I swapped around coilpacks but it's the same. All my spark plugs are new also. Does anyone have advice?
#37
Well there is the video with the 202 and a 55k, so it looks like he had it in. The question is did he get it to go with the ecu or was he running it on switches and and a modified computer. Also we know he blew the engine, but I doubt that had anything to do with having it in the 202 (or did it).
I'll try to look over all of his posts when I have some time, this is a very busy week for me. Without wanting to get locked down into a build everyone is going to expect, I am thinking about sleeving the 5.4, throwing in forged rods and pistons, possibly switching out the cams with some other stock cams, and getting a blower. I dont think I really need to polish the heads, crank,,etc since its a blower but maybe I will since its all apart already. I'm also looking to buy a house and a couple more cars so project is suffering a bit.
#38
So I recently dyno'd my W202 C55 and came out with some garbage power figures. The car was ran with a bad MAF and bad bank 1 sensor 1 Oxygen sensor. Also after the dyno on the way home my differential blew out. The oil coming out was extremely black and I think that's what caused the power loss along with the other two maintenance items needing replacement.
The car is currently in the shop and will be receiving all new parts. (Old diff had about 200k miles on it). Definitely the car should run high 12's with all parts being replaced. Hopefull... lol
Small video I made of the car:
Race with a C55:
Race with a C55:
#39
I agree, those power figures look pretty low. IIRC a stock, healthy C43 puts down 249hp at the rear wheels and roughly the same torque. There's no way you're losing over 100 ft lbs of torque and 90hp in drivetrain loss. That's a 28% loss, should be no more than 15-18% loss, just spitballing. Some newer cars with super light manual transmissions (like mustangs) are only losing like 7-10%.
Not the first time I've heard of gunky rear diff causing power loss. I really should look into changing my diff oil, too.
In that race vid, I assume your car is the one farthest from the camera? What kind of car is the one with the camera? Also, if your car was running the same in that vid as it was on the dyno, pull that w203 C55 after your repairs for a good comparison.
#42
wow... strange curve that is..
this is mine: https://mbworld.org/forums/c36-amg-c...went-dyno.html
#43
