C63 AMG (W204) 2008 - 2015
Looking for Transmission fluid change instructions
Old 03-24-2011, 11:30 PM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Anyone have them.. or a quick description. I found instructions for a w203 C280, but I am pretty sure our transmission is significantly different.
Old 03-24-2011, 11:34 PM
dodger63's Avatar
2013 f250 6.7 diesel
It is a pita
Old 03-25-2011, 10:24 AM
jvanbrecht's Avatar
I figured it would be a pain, but is it possible..... I'm okay with pia, I have vacuum and pressure pumps for moving fluids around, so it would just be a matter of replacing the gasket and filter (if needed)..
Old 03-25-2011, 11:11 AM
whipplem104's Avatar
1990 300ce supercharged and intercooled
The transmission is filled from the drain hole. So first you have to be able to do that. Then the level is set by fluid temperature. We use the SDS for this at work but you can check it with an infrared thermometer on the pan and just do it a little lower temp to account for exchange loss. Set it at 110F. Spec is 113F.
With the fluid overfull at around 6 quarts fill engine running open the drain plug and let the fluid drain out until you see the stream start to grab air or flutter. Put the drain plug back in and you should be good. There is a tube extension on the drain hole that sticks up about 2.5inches that must be on when you do this.
There is a special tool for knocking this tube off when draining.
Old 03-25-2011, 11:34 AM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
To save you alot of aggravation, best to take this in to the stealership and let them deal with it.
Old 03-25-2011, 11:44 AM
jvanbrecht's Avatar
Okay.. never mind then.. going to let the stealership deal with it.. that is alot more intensive then the C280 instructions I found....
Quick Reply: Looking for Transmission fluid change instructions
