Just tested 100-200 km/h
C 63 fully loaded
Hi!
Got my PerformanceBox for the first time in the C63 (bone stock except for 265/30/19 rear tires). A bit disappointed... Only managed 0-100 in 5,5 sec (worst launch ever, spinning tires all over the highway) and a 0-200 time in 16,5 seconds (i.e 100-200 in 11 seconds). I was alone in the car, 3/4 tank of gas left.
11 sec 100-200 I guess is OK. With a tuned car, what could I expect 100-200 km/h?
Hi!
With a good tune you should be just as fast. Im a stock P31. A couple OE tuned cars have run faster.
Also not all runs are that fast. Average 60-130 10.0-10.2
C 63 fully loaded
Iīll change to mph and will try 60-130 mph (and 120) so I have something to compare with.
C 63 fully loaded
My stock C63 does 60-130 mph (96,5-209,1 kph) in 12,9 seconds!
S-mode and esp sport.
http://fastestlaps.com/cars/mercedes_c_63_amg.html
Here are some times. It's stock though so the 0-200 should be considerably faster with the tune if you're around 500 hp
C 63 fully loaded
Sweden. About 220 meters (720 ft) above sealevel (sorry about the lousy graph resolution from the performancebox). Temp 5 degr C (41 degr F).
Forgot to inform you. Most of us run our best times in Manual Mode and start in 3rd gear to avoid the 2-3 shift since our trannys are slow! Also dont shift out of 4th gear take it to redline in manual. If you are in Sport it will shift aroound 128mph and the extra shift will hurt your time. Stay in 4th and you can run it to about 132mph.
Try this and I bet you will get better times.
C 63 fully loaded
C 63 fully loaded
12.9 is the time listed for a stock M3 6 speed. I think DCT is 12.5. You should be able to run some where around mid 12's.
Anyhow, now I have a baseline time and I have something to compare with after my car has been Kleemannized!
