AZNOptics.com Storefront - W204 AMG
#76
SPONSOR/MBworld Guru
Formally announcing that all our V3 units have not been adapted with Gel Packs. This is a high temp resistant gel substrate that we've applied to the resistor and critical solder joint to both help encapsulate the heat and insulate against heat soak, making these units more durable against heat and electrical surge related incidents.
#78
bump. We'll be introducing a new line of H7 and H11 plasma LEDs in the next few weeks. These would be ideal for fog lights if you don't want to upgrade to HIDs. Package will be put together with big Morimoto load resistors.
#79
Any pics of these fitted and in action Mike ?
#80
New V5 design is now available. These utilize cooler burning COB based diodes matched with our surge protection circuitry from our V4 line.
Offered in 4300K (matches better with OEM halogen and older HIDs) and 5000K (pure white)
4300K: http://www.aznoptics.com/index.php?m...products_id=96
5000K: http://www.aznoptics.com/index.php?m...products_id=95
#82
Twist off the dust cap, and pull out the socket that's pressure held. It's free twisting so might need to twist it a bit to loosen any dirt/grime. If you can't get a good grip, angled needle nose pliers help. Then just pull out the OEM halogen bulb and plug in these LEDs.
#83
on the other hand, i've recently received some new v5 leds from michael that are working great. they're brighter than the v4 line and do not have the flickering problem that the former tends to develop. also, michael's customer service is top notch.
#84
I just changed my eyelids yesterday they are not hard per se just hard to reach too. I put the caps back on but I don't think even one went on the way its supposed to as I saw the white rubber seal sticking out. I just made sure they were tight enough so as to not fall and left it. lol
I replaced my eyelids with PIAA white lights bulbs though and not LED's as the LED's I put in my old C350 kept burning out/flickering. Couldn't deal with changing them out all the time.
#85
Michael, I'm looking for a brake/backup (red/white) light to be fitted on my Vorstiener FL rear diffuser (within the mesh part)...you have anything like that? or can you custom make one? Thanks
#86
http://www.aznoptics.com/index.php?m...products_id=25
This comes with two strips, however they're both white. What you can do is spray tint one of them red though to match your tail lights for braking.
#87
The only thing I can think of is taking our 5 LED strip and splice it in to the brake trigger and reverse trigger wire.
Thanks...but they may be to short and not wide enough to fill the cavity
#88
Hello Mike I have your morimoto hid kit installed and has been going strong for over a year now. However my side marker lights were ordered via ebay prior to me discovering your website and now I need to replace my sidemarker lights. My main question here is do you think the 194 LED wedges would push up against the side marker itself ?
#90
They shouldn't. The new V5 units have actually a longer plate for you to insert the unit into which makes the length of unit post-socket comparable to our V3 units that had plenty of clearance.
#92
AZN Optics is now offering next generation Morimoto XB35 HID conversion kits. Available for order on our site www.aznoptics.com or PM us for more details.
#94
No sorry, you will need additional relays or code out the corning function.
#95
Hello... I am looking for W204 license plate LEDS to replace ones I have burnt out. Prefer white, but doesn't need to be super bright, just clean. Plug 'n play please... Thx.
#96
#97
2009 C63 AMG
#98
2017 C63S Coupe
Hi,
I have a 2012 Coupe, with intelligent light system. I'm not sure if this is standard or not...but anyways, I'd like to simply make the night time headlights brighter.
I was sitting at the lights next to a new E400 coupe, and that lighting system is noticeably brighter. Would love to have something like that.
What would you recommend?
Thanks in advance
Thanks in advance
#99
Go with 5000K. It'll be a very close match
You can upgrade your low beam D1S bulb. If you want something brighter, I'd suggest the Morimoto D1S XB55 bulb. We only carry XB35 bulbs, but can have an XB55 bulb special made for you if you wish. XB55 burn brighter, but has a slightly shorter lifespan than XB35 (still about the same as your OEM). Additionally, if budget isn't an issue, we can also get you Osram Xenarc 66144 CBI which are probably the best D1S bulbs on the market. Let us know!
Hi,
Thanks in advance
Thanks in advance
#100
2009 C63 AMG
