Please help, slight jolt after complete stop
No matter how gradual/subtle, or how quickly I come to a complete stop, I feel a jolt immediately after it stops. It feels like I get slightly rear-ended, but there's no car behind me. It only happens in sport mode, not comfort or manual. It started happening last week. Any advice is appreciated. Thanks!
Mods: Tune (May 2011), Coilovers (Jan 2011) and Exhaust (June 2009)
Mercedes C63 amg, Bmw X5,
EuroCharged 2012 C63 BS Coupè
2009 C63 AMG / 2007 BMW 130i M Sport
If not, take it to the dealer. Or do it before resetting it. Your call
Thanks for all of your input. I guess you guys were right, it was the shifting from 2nd to 1st. I did the easy ECU reset found here https://mbworld.org/forums/w211-amg/...set-works.html
Problem solved.
I hope your car runs better than ever after service Djovovic63.
Problem solved.
Problem solved.
Problem solved.
i thought i read that this wouldn't work on the c63 but if your problem is gone, then it must do something...
i was going to consider unplugging the battery for a while to reset it like from this thread
https://mbworld.org/forums/c63-amg-w...ml#post4738242
Problem solved.
Problem solved.
I've done the sneaky ecu reset before and that never did anything?
I had this issue from the beginning, a small jerk and clunk while in S mode when the car shifts from 2nd to 1st, and also in M mode. Comfort mode obvioulsy does not do this. However, after the car warms up, the jerk/clunk is gone in all modes when going from 2nd to 1st. That is why in the morning I always start out in C mode until the car has warmed up for about 5-8 minutes, then change to S or M and avoid the issue.
now that i think back, i remember having experienced something similar to this... if you're at a stop and you'r in C mode, your car will be in 2nd gear... but if you change it to S or M mode, it'll drop into 1st gear... i remember noticing that when it dropped to 1st gear, the car shook... but now i don't notice it doing it that much... i'm not sure if it has to do with warming up, but it could be...
majority of the time i just drive in C mode since it always resets back to it... and whenever i feel like it, i'll switch it to S or M mode later on.
