Did a burn out today...
1 Post
2020 A35, @021 F250, 96 Mustang
turned off ESP and stomped the gas pedal in M1. It seems I might have an LSD in my car - 2 lovely rubber tracks left in the parking lot.
Any other possible explanation? Does the stock open diff ever lock up or is it purely a 1 wheel at a time? If the car does have an LSD, how do I tell if it's the MB or 3rd party?
i have tried the method of rolling the tires while both rear wheels are off the ground, if it rotates the same way, i was told that it means it does have an LSD, if both wheels rotate at opposite directions or one wheel does not move, it means it is an open diff. I tried it after my Quaife went in and indeed those directions were to be found true.
If you get a bunch of rock chips and scratches on the dirt side you have an open diff. If in addition to the scratches you smell nasty clutch burning and your diff starts to leak oil, you have yourself a new LSD in a few weeks, cause your first one is shot.
I tried the same with my old CLK 55 AMG and direct get an error code. Didn't know which one it was but that isn't a good idea
