C63 AMG (W204) 2008 - 2015
Results from Atco Last night!!! 11/11/2011
Old 11-12-2011, 03:18 PM
PetroC63's Avatar
2012 CTS-V
Thumbs up Results from Atco Last night!!! 11/11/2011
Here are all my runs from last night. New personal best in MPH(124.28) and narrowly missed a best ET.
Track prep was average at best.
Run 1: 11.862 @ 120.48 (DA: -785) 60' - 1.906
Run 2: 11.713 @ 121.59 (DA: -884) 60' - 1.874
Run 3: 11.620 @ 122.27 (DA: -884) 60' - 1.843
Run 4: 11.548 @ 122.69 (DA: -884) 60' - 1.817
Run 5: 11.848 @ 121.39 (DA: -978) 60' - 1.943
Run 6: 11.802 @ 121.18 (DA: -978) 60' - 1.906
Run 7: 11.791 @ 121.08 (DA: -978) 60' - 1.883
Run 8: 11.818 @ 121.53 (DA: -978) 60' - 1.943
Run 9: 11.541 @ 123.18 (DA: -1010) 60' - 1.834
Run 10: 11.592 @ 122.88 (DA: -1010) 60' - 1.869
Run 11: 11.596 @ 122.47 (DA: -1010) 60' - 1.854
Run 12: 11.428 @ 123.92 (DA: -1010) 60' - 1.778(Manual Mode)*
Run 13: 11.423 @ 124.28 (DA: -1108) 60' - 1.784(Manual Mode)*
*All runs were made with traction control OFF and in Sport Mode with the exception of my final two runs of the night.
Awesome DA!!!
Next step is MHP Headers and Mid-pipes and back to Atco for a track rental on Dec. 5th.
Attached Thumbnails Results from Atco Last night!!! 11/11/2011-picture.jpg
Old 11-12-2011, 03:25 PM
xtyper's Avatar
2013 E63 AMG
Great runs mike! Look forward to your MHP header results next month.
Old 11-12-2011, 03:32 PM
bluejae's Avatar
'10 C63
awesome!
what tires?
are those numbers already da corrected?
so you didn't make any runs with tc in sports?
Old 11-12-2011, 03:45 PM
PetroC63's Avatar
2012 CTS-V
Thanks Eric. New headers should be on in about 1 to 2 weeks.
Originally Posted by bluejae
awesome!
what tires?
Thanks, I used Nitto drag radials.
Not corrected. DA info was acquired form Dragtimes.com.
I did not use TC this time. I kept lowering rear tire pressure until I found a sweet spot. Got down to about 17psi for the last two runs and they hooked pretty good.
Also, I really nailed the shifts in Manual Mode on the final two runs.
Old 11-12-2011, 03:48 PM
bluejae's Avatar
'10 C63
that was part of my next question... what did you shift at in manual?... and how is it shifting from 1-2
Old 11-12-2011, 04:35 PM
PetroC63's Avatar
2012 CTS-V
I shifted from 1st gear about 6300 to 6400 rpm. You have to be quick because if you delay you will hit the limiter and the run is ruined.
2nd and 3rd gear was about 6500 and not as quick to rev as 1st gear.
Old 11-12-2011, 04:40 PM
gthal's Avatar
2012 C63 coupe
Impressive!
Old 11-12-2011, 05:02 PM
propain's Avatar
See Sig
Awesome DA!!!
Great runs Mike. Not much difference overall from your best ET even considering the big neg DA. Good baseline of your current setup with the MBH headers. Look forward to see how much the MHP's can improve your times.
Old 11-12-2011, 05:14 PM
PetroC63's Avatar
2012 CTS-V
Thanks Jim.
I was hoping to improve on the ET considering the DA. I wasn't able to achieve a similar 60' time(1.72) as I did back in May when I ran my personal best. I think a 1.72 last night would have netted me an 11.3 run.
Oh well, I did what I set out to do, which is get some baseline numbers.
Old 11-12-2011, 05:20 PM
propain's Avatar
See Sig
Thanks Jim.
Exactly. Even the 11.3 with the better 60 would be explainable by the better DA. I think you have a solid baseline to move forward with the MHP headers and document any improvements. I hope I'm there! You should do it at ATCO so it will be documented on the same track so no one can say the improvements are the different track.
Old 11-12-2011, 05:32 PM
hotrod182's Avatar
335i
Which Nittos did you use? NT505R, or NT555Rs?
I went all the way down to 21psi on the NT555Rs, but was afraid going any lower than that wouldn't make any difference.
When you got your record run last time, did you already have the LSD then? How much do you figure the LSD helped your 60' times?
Old 11-12-2011, 06:04 PM
PetroC63's Avatar
2012 CTS-V
I plan on being at the Dec. 5th Atco track rental. I'm hoping for a 40F sunny
day so the sun can bake the track for better traction and the cool air can help make some serious power.
Old 11-12-2011, 06:06 PM
propain's Avatar
See Sig
So many rentals coming up. This TTM's rental?
Old 11-12-2011, 06:10 PM
PetroC63's Avatar
2012 CTS-V
I've been using NT555R's.
Normally I start my rear tire pressures at 20psi and work my way down. Most of the time if track prep is good 20psi is sufficient. Last nights track prep was average so I lowered them to 18psi and finally 17psi. I was going to try 16psi but the track was closing.
I've had the lsd for well over a year. The main reason for an lsd for me was to absolutely make sure both wheels spin during a burnout. dodger63 ran 10's without an lsd so it's not a necessity.
Old 11-12-2011, 06:11 PM
PetroC63's Avatar
2012 CTS-V
I think so. Mike(dodger) started a thread over on the other site.
Old 11-12-2011, 06:42 PM
propain's Avatar
See Sig
Ahh ok, ill have a look.
Bruce from TTM is putting something together as well. Not sure if its the same one. Either way... Its race time! Gotta get in 1 before the snow.
Old 11-12-2011, 06:47 PM
Mort's Avatar
Congrats, nice runs. Looks like a great baseline for your header comparo!
Old 11-12-2011, 06:50 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Once the headers and mid pipes, with a better 60' you may be very close to 10s
Old 11-12-2011, 07:37 PM
Dads C63's Avatar
2014 Audi RS7
Congrats Mike!!
I'm sure you had a great time. Good luck with your new set up!
The additional torque will make a difference!! Have fun and be safe!
Old 11-12-2011, 07:38 PM
PetroC63's Avatar
2012 CTS-V
Thank You. It should be interesting.
That's the goal, it's not going to be easy. Everything has to be perfect to run
that number.
Old 11-12-2011, 07:50 PM
PetroC63's Avatar
2012 CTS-V
Originally Posted by Dads C63
Congrats Mike!!
Thanks Keith.
I'm hoping for increase in torque and for the torque curve to shift downward from the difference in header design. It would help my 60' times immensely.
Right now I feel the 2" primaries are having a negative effect on my low end torque.
Old 11-12-2011, 07:56 PM
dodger63's Avatar
2013 f250 6.7 diesel
Great run
Old 11-13-2011, 10:51 AM
no loser's Avatar
c63
Congrats Mike you did great run
keep it going and Smiling for 11.2
Old 11-13-2011, 05:15 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Good runs Mike, congrats
For some reason I thought you were already running the MHP headers and tune, but I just realized you don't have the MHP headers installed yet. Do you know what was your best ET and Trap before and after the MHP tune?
Old 11-13-2011, 07:45 PM
Helms's Avatar
C63 AMG
Awesome results man.
Quick Reply: Results from Atco Last night!!! 11/11/2011
