Help needed - Changing gear set of differential
C63 T Modell
Hi
I want to change the gear ratio of the differential of my C63 from the original 2,82 to 3,06. With this shorter gear ratio I hope to get more dynamic in the 4th to 7th gear because I think the original ratio is to long.
The differential for the mod and the softwareupgrade are ready. Only Problem is to get the gear set with a 3,06 gear ratio. Mercedes doesn´t offer this as spare part and so I´m only able to buy a second differential with the right ratio. But I want avoid this if possible and get only a gear set.
Hope someone has an idea or better a adress where to buy.
Hi
A small, fine, but very specialized company in the south of germany
he made the coding via OBD!!!
