M156 head bolt problems
#752
I apologize if answer is somewhere in these threads and I missed it.
But does anyone know if it's possible to pull the valve covers and pull one bolt to check for rust?
Without messing up the timing..
Still new to the M156.
#753
07 E63 + 07 CLK63CAB
You do not realize just how lucky you have been, by having a independent machine shop work on the heads which by the sounds of it the shop either used the wrong valve guides or reamed the guides to a too tight tolerance which caused the valves to stick. Mercedes rep must have been drinking heavily on the previous weekend to allow coverage of the engine after the head work was done.. Not giving you static , but boy are you lucky.
#754
C63AMG, NIssan NX2000, Pontiac Fiero GT
Dunkin, Some would replace the old bolts one at a time. So you could check if you like that method, but then replacing with the new bolts makes better sense since you are already there. We do not know if one or two positions in the head are especially vulnerable. But snapshots of 10 removed bolts, for instance, do not show numerous bolts broken, usually 1 or 2.
#755
Unfortunately this won't work for several reasons. The head bolts are torque to yield and cannot be re-used. The head bolts must be torqued a series of times in a specific sequence. Undoing one head bolt and then replacing it will a new one may have the unintended consequence of causing a head gasket failure. Some of the head bolt are underneath the cams and cannot be accessed without removing the cams. Hence it is an all or nothing process to replace them.
#756
Any particular engine model numbers that were affected by this? I got a 2009 recently was curious is all
Curious if Im in the affected range WDDGF77X09F320315
2year warranty so Im not to worried, but not too happy I found this information after I got the car. *knocks on wood*
#757
Yes you are.
Joe
#758
Sweet! guess if it happens then it happens.. I dont want to worry myself over something I have no control and only have had the car for just over 2 weeks. I got it to enjoy it not stress lol I do wish anyone luck thats outside of the warranty since that seems to be when it usually occurs most.
I already let my dealer know Im aware of the issue so fingers crossed.
Thanks Joe
Thanks Joe
#759
I am only changing mine as a precaution.
#760
The cams are easy to remove with the MB tools and the engine at 40degress, the mb tools lock the cams in the correct position for removal and install.
#764
Errrr wrong. Tons of guys driving around without a problem. Guys even running blowers with these bolts, nitrous too!
Some pop, some stretch, some don't. Enjoy your day.
#766
2007 Mercedes Benz CLS63 AMG
Full Agreement
Ok, here's my screaming into the wind moment
I believe Mercedes Benz should pre-emptively replace the head studs on every 6.2 liter engine effected by these faulty head bolts.
They've acknowledged the problem through a redesign of the studs used and I think it's pretty shltty that they let AMG owners get whacked by this disaster waiting to happen. Not a matter of if but a matter of when. And if I bought one of these cars unknowingly, I'd be pushing the issue until it was done on my car.
To have that part be the weakest link in this engine is a problem Mercedes Benz needs to address with each and every owner of that engine to make it right.
I'm just saying what everyone thinks...... As unlikely as it is, this is the RIGHT thing to do for a prestigious brand.
Rather than wait for MB to "Do the right thing" in this complete engineering failure, I decided to pay the bill and get it back on the road after the catastrophic failure of one of my head bolts. Car is awesome and I'll never see a dime of reimbursement as I bought it used post factory warranty without doing the full research based on the performance and reliability of my two previously owned bulletproof MB cars.
I will say that the cost of the repair shifted this car from a decent value purchase to one of the worst value vehicle purchases I have ever made. I could have bought an extended warranty at the time of purchase but didn't as I have done this in the past and wasted a few thousand dollars in the cost and interest as they were added to the contract. In this case it would have paid off in spades. My crystal ball was broken that day I guess.
Having said all that, the car is still the best car I have ever and likely ever will own.
I say buy the extended warranty and enjoy the car for what it is. AWESOME!
#768
2009 C63, 2000 Nissan Maxima
Since I am mechanically challenged, would it make sense to have Long Tube Headers installed at the same time as replacing the HeadBolts? or is that a completely different set of parts/install?
#769
Although the name may be similar they are completely different parts in complete different parts of the engine.
These are headbolts (technically these are studs but this is where the head bolts go). You're just thinking of where the headers connect which isn't even shown in this picture.
#771
If the heads have to come off for the replacement (some have talked about replacing them one at a time without removing the head), then the exhaust manifolds have to come off and there will be an overlap of labor. What does that mean? It means that it would cost you a little less to swap the headers. If the headers and headbolt swap are in the near-future, I'd have it done at this point.
#772
my C has 27k miles and i dont have any reason to believe my headbolts are in danger, other than what has been discussed here, how many are changing them as a preventative measure?
#773
'10 C63 AMG
thats what i was wondering! i understand that they may not be in the same exact area, but if I were to have headers installed, it would make sense to do the headbolts at the same time
Will probably look for a good indie shop and eventually get them replaced before warranty ends though
#774
It's the other way around.
If you are doing head bolts, then swap the headers. If you are only doing headers, then the heads do not need to come off.
#775
