Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C63 AMG (W204)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C63 AMG (W204) Discuss the C63 AMG
Sponsored by : Kleemann USA
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-20-2012, 09:56 AM   #1
Drives: .
What causes this type of tire wear?
Front right tire separated on the inside edge. Would an alignment fix this excess/uneven wear ... or, is this 'normal'?
To remove this ad, register today or login if you already are registered!
What causes this type of tire wear?-t1.jpg   What causes this type of tire wear?-t2.jpg   What causes this type of tire wear?-t3.jpg
ashva is offline   Reply With Quote
Old 05-20-2012, 10:22 AM   #2
503C43 ////AMG's Avatar
Drives: 1 out of 1125 C43's imported to U.S.A
From the pics it looks like you have wear on the outside edge indicating positive camber.
The separation appears to be on the inside edge
Doesn't make sense
__________________
  • 19" Mandrus Milleniums (8.5" + 9.5")
  • Vogtland Springs
  • Bilstein Sports
  • K-MAC Camber/Castor kit
  • MB Arts Rear Camber arms
  • 2nd Cat + Res. Delete
  • Cryo Treated AMG Rotors
  • Stoptech SS Brake Lines
  • Akebono Euro Brake Pads
  • HID Lights + HID Crystal fogs (55w 6k)
  • Tinted Windows (20%)
  • Avantgarde Grille
  • Evosport UD Pulley kit
  • Evosport Phenolic Spacers
  • Renntech CF airbox
  • AFE Pro Dry S Filters
NEXT:
  • Eurocharged ECU Tune (Purchased)
  • Kleemann Headers (Awaiting install)
  • Metal Cats
503C43 ////AMG is offline   Reply With Quote
Old 05-20-2012, 11:12 AM   #3
Drives: C63 AMG
What does the other front look like? Does the car pull to one side?
My best guess would be under inflated or a faulty tire/side wall. Contact the tire manufacturer.
Merc63 is offline   Reply With Quote
Old 05-20-2012, 12:16 PM   #4
Drives: 97 Porsche GT2 Wide Bodied Cabrio, Mercedes G500
Send a message via MSN to Rsquad911
Could be a camber or too much toe out.
Go to an alignment shop... Maybe you hit a hard bump/pothole on that side.
__________________
P.Tien
"Never Drive Faster Than Your Guardian Angel Can Fly"
1997 GT2 Wide Bodied Porsche 911 Carrera (Fully built 3.8L Supercharged, H&R Clubsport, Kinesis K28R, GT2 Flares, Ruf bumpers)
2012 Mercedes C63 AMG APX/PP (AFE Pro-Dry S Filters, ROW Air Boxes, MBH X Pipe, KW V3, ADV1 10TS and Tangent Titanium Bolts)
2005 G500 (Bush bars, AMG wheels and K&Ns)
1981 911 SC (RUF YellowBird kit, BBS LM, SSI headers)
Rsquad911 is offline   Reply With Quote
Old 05-20-2012, 12:54 PM   #5
Drives: 2012 C63 AMG
That's an awful lot of wear on the inside edge. My first thought was toe/camber, but from the looks of the affected area, it looks like it is wearing differently than the other parts of the tire in the first picture. Like the others have said, it's weird to see wear on both the inside and outside edges. It looks like the outside edge is wearing a little more than the tread, so I'd say its got a slightly positive camber.
Is the car lowered? The only other explanation I can think of is that the tire is contacting your suspension causing abnormal wear and separation...
__________________
2012 C63 AMG Sedan - Magnetite Black - Designo Black Single Tone Leather - Premium Package - Rear Seat PP - 19" AMG Multi-Spoke Wheels - AMG Wheels w/ Winter Tires - XPEL Front End Protection - Window Tint - Smoked Side Markers
Illusive is offline   Reply With Quote
Old 05-20-2012, 12:57 PM   #6
Drives: C63
on a somewhat related note...i got my tires changed yesterday. they wanted to do an alignment to fix the camber or something, because the two rear tires were worn on the insides. i told them i didn't want to mess with the camber setting. is this how it's supposed to be?
SheryarYO is offline   Reply With Quote
Old 05-20-2012, 01:14 PM   #7
Drives: C63
Lowered suspension + wider than standard tyres?? I would be suspicious the big strip that has been torn off is from the tyre coming into contact with lip of the mudguard/wheel arch eg from hitting a bump when cornering hard
JimmyR is offline   Reply With Quote
Old 05-20-2012, 02:35 PM   #8
Drives: 600RR, 09 C63
It looks like a pot hole puncture, Or the belt shifted. If this tire was on the left side of the car its too much negative camber, if. It was on the right side, it would be too much positive camber. If you don't want bad wear on the tires you can ask them to align the car with a little less camber front and back, but it might effect the ride handle a bit
shades is offline   Reply With Quote
Old 05-20-2012, 03:55 PM   #9
Drives: .
Thanks for the info so far.
Attached pic of the left front tire ... wearing the exact same way.
Tire pressure is at ~40 lbs.
All stock ... not lowered or any other changes to the suspension.
Tires have ~30K on them which I have been thinking is too good to be true (on 3rd set of rears) but have always just gone by the wear bars ... never looked at the inside of the tire ... lesson learned.
Thankfully I never lost pressure ... could have been ugly ... especially since i was taking advantage of some open road shortly before it separated.
Was in for service B ~ 2 months ago ... kind of surprised the severity of the wear wasn't mentioned.
Old 05-20-2012, 07:06 PM   #10
Drives: 2010 C63 P31;1971 280SE 3.5(Sold);2003 1500 HD Silverado;2008 R320 CDI (sold);2011 GLK350 (wife's)
Quote:
Rear camber is not adjustable. Only rear toe-in is adjustable.
__________________
Mort is offline   Reply With Quote
Old 05-20-2012, 07:11 PM   #11
OP I think you may have toe-out on the front as mentioned and I would definitely get the alignment checked.
__________________
Old 05-20-2012, 11:23 PM   #12
c63canada's Avatar
Drives: c63 amg
you paid for a 500$ service and from what I see they didn't check your tires. Impossible that they were close to ok 2 months ago unless you tracked the car or drove it pretty hard. And they tell you that you pay more (for what is basically an oil change) but it's for your security ....
BTW i have the exact same type of tire wear. it looks as if the inside portion was buffed or shaved at a 45 degree angle???
c63canada is offline   Reply With Quote
Old 05-20-2012, 11:41 PM   #13
Drives: 2010 C63 AMG, 2010 ML63 AMG
You are experiencing what many have. It is related to an aggressive camber setting and causes this type of wear. "Fortunately" I pinched a right rear on a bad driveway apron and blew the tire. When I pulled it off I was shocked to find the inside edge worn to the belts. I put on some P-Zero Neros which were crap. I changed to Pilot Super Sports and have yet to go have the alignment setup to minimize the camber and maximize tire life.
There are several threads about premature tire wear and alingment settings on the forums.
Regards,
Joe
Valvestud is offline   Reply With Quote
Old 05-21-2012, 08:40 AM   #14
I should clarify/correct my last response. It's actually the toe in that seems to impact the rapid overall tire wear, as the tires scrub as they roll. But I also feel the camber is having an impact on the inner areas.
Regards,
Joe
Old 05-21-2012, 08:32 PM   #15
I hate to say this bro, but from the look of your last pic your gonna need front struts soon. If you run your hands over the tire and you get a wave like feel in your hand, then it's probably time for a change. It looks like your tire might be skipping (not full contact on the road). When you put the new tires on, have them check your struts.
Tags
2012, adjusted, alignment, c63, camber, class, front, inside, rear, silverado, thready, tire, tires, uneven, w204, wear
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
