C63 AMG (W204) 2008 - 2015
Chrome door handle inserts....Easy to remove??
Old 05-21-2012, 02:53 PM
Swoody's Avatar
2012 C63 Coupe
Title says it all.....how hard are they to remove??
Thanks,
Swoody
Old 05-21-2012, 02:55 PM
VaclavSV's Avatar
2012 C63 AMG Black Series
+1 I hate them on mine too
Old 05-21-2012, 03:08 PM
olszowa12's Avatar
'08 C63 Estate
I don't know how hard it is to remove them, but I wrapped mine with gloss black vinyl
Old 05-21-2012, 03:21 PM
Swoody's Avatar
2012 C63 Coupe
Putting a wrap overlay on them was my first idea as well...but if they can just be taken off I would probably go that route.
Old 05-21-2012, 03:42 PM
Rsquad911's Avatar
97 Porsche GT2 Wide Bodied Cabrio, Mercedes G500
If you take them off then you'll have a bunch of holes and clips left underneath.
Old 05-21-2012, 04:11 PM
Swoody's Avatar
2012 C63 Coupe
Well then....vinyl overlay it will be!
flooby's Avatar
2012 C63 Sedan
Wrapped mine in gloss black also
Old 05-21-2012, 07:35 PM
blackc230benzo's Avatar
2010 C63, 2003 C230 coupe
Thanks,
Swoody
Very easy
-Unplug the rubber cap , just pull
-Use a t20 torx screwdriver, use a 6" length to reach the screw for rear doors.
-loosen the screw but don't remove it from the threading.
-Pull the handle to the open position, and the part that stays on the door can be jiggled and slid forward and out once you have loosened the screw out of it.
- With the smaller piece of the handle out The electronics are easily disconnected by a push tab.
-Once the smaller part of the handle is out, the other piece comes out easily.
-The large chrome comes off with 2 screws and the smaller chrome piece has a release tab.
5 min max.
I removed them to vinyl so there are no visible edges.
Old 04-09-2013, 12:06 AM
andrew c230k's Avatar
W204 C63 R171
Anyone who has wrapped the door handels or painted them does everything work how its supposed to ie keyless entry, keyless go... I noticed tonight taking apart the handles that the top chrome bit has a electrical contact going to it.
Old 04-10-2013, 01:04 AM
Dark_Knight's Avatar
GT2 C63 and yo sister
WTH I thought these were just stick on, I've got a piece of clear vinyl in my handles to prevent scratches, I was going to add these, now not so sure
Old 04-15-2013, 11:14 PM
LAMB09's Avatar
2011 C63 AMG
Originally Posted by blackc230benzo
Very easy
Can anyone confirm how to take off the chrome piece from the small non-handle part. I couldn't figure it out and didn't want to force it and brake something.
Old 04-15-2013, 11:23 PM
JonMBZ's Avatar
06 C55, 09 E350
Maybe you are getting confused like I did at first, these are door handle inserts to me.
Attached Thumbnails Chrome door handle inserts....Easy to remove??-mercedes_chrome_door_handle_cups.jpg
Old 04-16-2013, 11:40 PM
LAMB09's Avatar
2011 C63 AMG
Bump, can anyone help figure out how to get the small piece loose? Original post said there is a release but not sure which direction it comes loose.
Old 04-17-2013, 09:45 PM
ok so this is not about whats in the picture? because what you posted are door handle inserts to me too, I'm still confused
Old 04-18-2013, 10:02 AM
Mort's Avatar
Chrome/SS inserts on the tops of the door handles themselves. On cars with keyless go.
Old 02-12-2014, 07:04 PM
twelvehundred's Avatar
2014 C63
Possibly some confusion in this thread. Chrome door handle inserts are a $90 option on the newer models. In JonMBZ's picture, the insert is the large chrome piece that covers the interior well of the door handle. According to the dealer and some research I've done, they are stuck on with adhesive strips so there is regular paint underneath. I am definitely removing mine and will consider wrapping them in matte vinyl to match the window trim.
Old 02-13-2014, 01:12 PM
goatfarmer1970's Avatar
C63 Coupe 507, CLK55 Convertible, X1 35i, 70 GTO convertible, motorcycles
Definitely on with two-sided tape...easy to remove. I removed mine and then had a shop paint the chrome top part of the actual handle (that comes with Keyless-Go) in body color for $200. I know it is a small thing, but it made me like my car a lot more.
Quick Reply: Chrome door handle inserts....Easy to remove??
