C63 AMG (W204) 2008 - 2015
C' s with spacers
Old 05-30-2012, 01:49 AM
L8brker's Avatar
09 C63 P30/05 S4
C' s with spacers
Want to see some c63's with wheel spacers ,any recommendations ?
Old 05-30-2012, 03:16 AM
bhamg's Avatar
C63 AMG
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Old 05-30-2012, 05:09 AM
olszowa12's Avatar
'08 C63 Estate
There are very few pics with spacers so I'll help you out.
My car is lowered on 20mm H&R Springs.
I use Eibach spacers. Tires: 275/30/19 235/35/19
Front 15mm on each side
Rear 10mm on each side
10mm rear and 15mm front on stock OEM 18" (winter setup)
Final setup - 10mm rear and 15mm front
Old 05-30-2012, 05:25 AM
_AMG_'s Avatar
C63
Matt, your car looks sick!
Perfect stance.
Old 05-30-2012, 05:43 AM
olszowa12's Avatar
'08 C63 Estate
Thanks Carl
I have to make a small adjustment though and go with 255/30/19 in the back because I hear massive fender rubbing with two passengers in the back.
Old 05-30-2012, 08:54 AM
BK63amg's Avatar
'16 GTS Solar
I run 12mm front and 8mm rear with my stock wheels...rubs with 265 rear with passengers or deep dips.
Old 05-30-2012, 04:13 PM
LFM_Vancouver's Avatar
C63s now in the garage. Sold-GLA45 AMG Edition 1, Sold-2010 Mercedes C63
12mm H&R front and rear . Stock wheels and tires. No rubbing at all. Perfect
before and after photos
https://mbworld.org/forums/c63-amg-w...installed.html
Old 05-30-2012, 04:18 PM
DuaneC63's Avatar
AMG GLC63. Audi R8
Lots of people use spacers but it's not the best idea in the world. You change the offset which changes the alignment. You're adding unsprung rotational weight to each corner, (never a good thing). Any pick up in handling is minor so it just a looks thing.
Old 05-30-2012, 04:40 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Perfect stance.
I agree.. Matt, you must have the best looking estate in the world! And props for keeping it so clean & shiny after all these miles.
Old 05-30-2012, 06:26 PM
ChrisD63's Avatar
2009 040 Black C63, 2009 Arctic White G55, 2012 Storm Red CLS550 4Matic
On coilovers or springs?
Old 05-30-2012, 08:37 PM
L8brker's Avatar
09 C63 P30/05 S4
Thx olszowa12 that is exactly what I was looking for, sweet estate , ironically I have 10 and 12 mm spacers in my garage left over from my Audi S4
Old 05-30-2012, 08:59 PM
NovA_S's Avatar
2012 C63 Coupe. Eurocharged, Charcoal Filters Removed, R-S3 Tires
Hi guys I have a question to everyone. Should I put spacers on my 2012 C63 coupe or not. I have stock 18" wheels. Rear tires are 265 wide. I already ordered 12mm back and front spacers but than I start having all these negative feedbacks from different people who say that it's ether dangerous especially the way I push this car in the corners or it can damage the car as I change some... something
What do you think? Should I or should I not?
Old 05-30-2012, 09:38 PM
mvagusta's Avatar
bmw e-60 550i,bmw e-92 m3, c63coupe p31, stable of Italian stallions MV's
I have 12 mm in the back and 15mm in the front. 2012 coupe P31. The loook is perfect. Very agressive and looks good. The only preoblem I'm have now is should I buy H&R springs with these spacers. I don't know if it willl rub? Does anyone have a opoinion or a axample?
Old 05-31-2012, 02:45 AM
604 C63's Avatar
2012 E550 Cabrio
[IMG][/IMG]
[IMG][/IMG]
H&R sports on a P30. 12mm front. 10mm back.
Not worried about it at all. You know what scares me? Tires. I hear from some buddies that those things can go flat. And I have 4 of them on my car!!!
Seriously tho. I also got good quality bolts that are of an appropriate length and everything is fine. Had them on multiple cars. I am also unconcerned about the additional small amount of unsprung weight. Guys add more weight by changing their rims, or their rim size or the width of their tires.
I can tell you that every time you see a car in an ad they have done 3 things: lowered, spacered and tinted. I've now done all 3 to my car and I can tell that no matter what these crappy phone pics show (or dont) it now just looks right. The stance is perfect and the car looks much stronger.
Quick Reply: C' s with spacers
