Facelift Passenger side mirror help
C63
I just installed a set of facelift side mirrors that I got from Germany and they look great. However, the passenger side mirror does not seem to have the memory function and does not tilt down like my old mirror. Everything else works perfect(power adjusting/folding)
I tried setting it manually by putting the gear in reverse and setting the memory but that did not work as well. Selecting the passenger mirror while reversing also did not do anything. Did I get a defective mirror or is it something else?
The memory function works on the drivers side but not on the passenger side.
W204 C63 R171
Does your passenger side mirror go up and down correctly... I just installed mine my down is up and up is down only on the passenger side...
My mirror has the reverse feature.
I tried playing around with the wiring and there is nothing i can figure to correct the reversed movement.
C63
I think mine did not come with the memory feature. I found out that there were a few less wires in the plug as compared to my old mirror.
As a result I had to remove the entire motor/missing wiring from my old mirror and transplant it in the new one. Now it works fine.
If yours already has the reverse feature, then it should work fine for you. Might be a long shot but maybe you can compare the wiring in both connectors to see if they are arranged differently. It seems like the motor sits in only 1 place. If not, you could rotate it to reverse the orientation that that would be an easy fix.
