C63 AMG (W204) 2008 - 2015
Question: AMG hood emblem installation
Old 02-01-2013, 10:33 PM
Sidv22's Avatar
Audi A5 6MT, C63 AMG
Hey Guys,
Bought an AMG hood emblem from Jbspeed
http://www.jbspeed.com/servlet/the-2...-Emblem/Detail
Having a tough time during installation. First of all, the instructions provided by jbspeed are incorrect. Here is the link that was given and i am glad I didnt follo w the instructions blindly. would have been a disaster if i had used a screw driver.
http://www.e90post.com/forums/showthread.php?t=36738
I removed the stock emblem by popping up the hood and pressing the spring mechanism which hold the emblem in place. The problem is that the base of the aftermarket has greater diameter than the cavity where the stock emblem resides. Also, its unclear as to how to secure the metallic base in place (there is a pair of screw and nut provided)
Anyone has experience in doing this DIY? few pictures:
Old 02-01-2013, 10:55 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
If you got the right emblem type, it should be as easy as removing the standard one.
Old 02-01-2013, 11:02 PM
Ratven's Avatar
'09 C63 P30 Eurocharged
The issue that is not clearly explained now that I look at the set I was unable to install... is that you have to remove the stock silver plastic emblem from the stock black "locking mechanism". You then have to mount the new disc onto that locking mechanism using the screws provided.
I'm going to buy a replacement oem emblem before I attempt this in case I muck it up.
It is also a little worrisome that the size appears to not be a direct fit. The silver disc that comes from JBspeed seems to be a little larger in diameter than the oem emblem.
Also, I'm not exactly sure how to disassemble the stock emblem without cutting it up.
Old 02-02-2013, 04:12 AM
Sidv22's Avatar
My thoughts exactly! I think i might order a stock emblem before playing around. i tried to remove the spring mechanism from the stock emblem but it it wont budge and i thought i might break it.
unfortunately, the stock and the aftermarket emblem have different mechanism. the one from jbspeed does not have any spring mechanism, just the bottom heavy base and couple of screws.
Old 02-02-2013, 02:46 PM
Jason Anthony's Avatar
2013 C63 AMG Coupe
I have the EXACT same issue with jbspeed
Old 02-02-2013, 03:03 PM
Sounds like you guys have the wrong one.
Old 02-02-2013, 05:03 PM
2013 C63 AMG Coupe
yea - crappy service at jbspeed - how did they ship the wrong one to both of us? i checked the page again and I clearly ordered the correct one.
Old 02-02-2013, 05:47 PM
2013 C63 AMG Coupe
This is what Brian said from jbspeed:
put the sticker on the plate. after you take the stock one off, you take the stock emblem off from the plastic thing then put the new one on with 1 or 2 screws then put it back on the hood
This can't be right
Old 02-02-2013, 05:52 PM
2013 C63 AMG Coupe
He just asked me if I could see the screws....how do u unscrew that? It's plastic
Old 02-02-2013, 07:20 PM
2013 C63 AMG Coupe
I figured it out -
not a perfect fit though.
Yank the black plastic piece off the stock emblem. it shouldn't break. the white tabs might break and u just have to push them out.
then get the new screws and emblem in it but don't tighten it because it won't lock to our cars because the hood isn't flat there and the metal piece is kinda fat.
once it's on the car and locked in, then tighten the screws. use some rubbing alcohol on the metal to get oil off of it. then stick the 3m part on.
Old 02-02-2013, 08:50 PM
Sidv22's Avatar
Great! Thanks! I am going to try this first thing in the morning tomorrow.
Old 02-02-2013, 10:06 PM
c63edition1's Avatar
2013 Fiat Abarth
same thing happened to me but i still was able to install this type .. all you have to do is use a large washer and it will hold in place really well
Old 01-06-2014, 06:47 AM
idiver5's Avatar
C200K W203, C250 CGI W204
I have exactly the same issue and found this thread. Can you guys finally got it fit?
Old 01-06-2014, 07:13 AM
DialDforDan's Avatar
GTS
I thought about buying the same one you have. Glad I didn't as it sounds too shady for me. Appreciate the heads up!
Old 01-06-2014, 12:09 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Bought mine off ebay and I'm very happy with it.
It fits perfect and install was easy as for the OEM.
Here is the link:
http://www.ebay.com/itm/x2-AMG-Desig...6c6fc29http://
Looks like it's selling as a package of 2 now. When i bought it back in March 13 you could buy the hood emblem alone for 35$.
Old 01-06-2014, 12:50 PM
jordanaf's Avatar
507 SEDAN
I bought off ebay as well and had no issues. I bought 1 for $35, it came from Japan, and went on in 45 seconds.
Also guys, there are different size diameter hood emblems. I'm sure that you guys knew that I just wanted to put that information out there.
Old 01-06-2014, 03:23 PM
H20 MRV's Avatar
C63 - Golf Tdi
same with me, very annoying..
Old 01-06-2014, 08:35 PM
jarjoug's Avatar
2006 BMW 330i, 2009 C63
I had the same problem. I emailed them and they told me I bought the wrong one. I bought three emblems from them and did not get a satisfactory fit.
Old 01-06-2014, 08:42 PM
Vise_'s Avatar
2013 C63 AMG, 2013 B250
Jbspeed strikes again.
Old 01-07-2014, 09:42 PM
roadtalontsi's Avatar
10 C six trizzle
same problem here. I understand how it is supposed to install but the holes are not offset correctly so im having to make some modification to it. got to love 15$ cheap crap that takes way too long to fit correctly.
Old 01-08-2014, 01:32 AM
zibby43's Avatar
'20 GLC300 SUV
Here is the link:
Wish there was one available that has the modified A character that is present on all 2012+ cars.
The aftermarket has kind of fallen asleep on that one.
Quick Reply: Question: AMG hood emblem installation
