C63 AMG (W204) 2008 - 2015
OEM Differential Issue--Advice, thoughts??
Old 03-12-2013, 11:53 AM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
I checked in with Keith on this earlier---I'm in the middle of a Quaife LSD install and my shop found some metal shavings in the dif fluid and unusual wear on the gears. My first reaction (cost) was to put the car back together and run it. They did and I apparently have gear noise as well. We are discussing an OEM full differential (ring and pinion) assembly replacement with the concern being trying to avoid a big or bigger problem down the road. I haven't heard of guys having to make this big ticket replacement in the rear end. Has anyone experienced anything like this or any thoughts on the subject?
Old 03-12-2013, 12:02 PM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
I think either Dads or Jrcart would be the best resource because they run very very high RPMs and torque on their trannys and diff....they seem to say that they are able to take A LOT of abuse...
Old 03-13-2013, 10:28 AM
Case1906's Avatar
Thanks, I checked with Dads and he has had no issues. Looks like a one off problem for me at this point? Going to take a look at the gears later today.
Old 03-13-2013, 10:34 AM
Merc63's Avatar
C63 AMG
Never heard of any diff issues.
I have access to an OEM diff, no LSD. 60,000km on it.
Old 03-13-2013, 10:54 AM
Merc63's Avatar
C63 AMG
I believe the diff is a Dana 44. Same as the jeep srt 8.
I think dodger destroyed his stock diff.
Old 03-15-2013, 02:31 PM
Case1906's Avatar
Merc63-- please check PM.
Old 03-15-2013, 02:50 PM
ChrisD63's Avatar
2009 040 Black C63, 2009 Arctic White G55, 2012 Storm Red CLS550 4Matic
I had my car at the dealer to get something fixed and they ended up finding something wrong with the oem open-diff and they replaced it under warranty. I didn't even know there was something wrong with it until they told me.
Old 03-16-2013, 05:58 PM
Case1906's Avatar
Chris-thanks, did they give you any indication of what the problem was? Curious as to how they would see issues without tearing apart the rear end.
Old 03-16-2013, 06:20 PM
ChrisD63's Avatar
The exhaust was rattling and when they had the car on the lift I guess they noticed the diff was also making some noise, although I never heard it myself.
Old 03-17-2013, 01:51 PM
motoman's Avatar
C63AMG, NIssan NX2000, Pontiac Fiero GT
A competent shop would take a bluing reading of mesh and/ or shim/bearing eval and tell you specifically the problem. Why did they reassemble it if something was wrong?
Old 03-29-2013, 11:53 PM
Case1906's Avatar
Rest of the dif story... a transplant
I told them to, but thought better of it. My original thought for cost reasons was to drive it until it broke or I felt slippage. I finally saw the problem myself. Each gear had maybe a 1/4 inch long groove in the hardened steel and there was unusual wear on the corner of many of the gears. The car ran fine before, but the concern was that shavings would eventually damage the new Quaife and there would be failure (along the lines of what I learned happened to Dodger).
Rest of the story--My shop located a C63 in Massachusetts with 4000 miles that was totaled as a result of a fire. (Anybody here?) They purchased the OEM dif assembly, swapped out my old one and installed the Quaife. I'm back on the road with some peace of mind about the dif. Maybe I would have never had a problem, but after seeing the gears I feel good about the fix.
Old 03-30-2013, 10:22 AM
motoman's Avatar
Case, glad you're good to go now.
Old 03-30-2013, 03:50 PM
Case1906's Avatar
Thanks, do you still have the Fiero? I always thought that was a neat car back in the day.
Old 03-30-2013, 09:15 PM
motoman's Avatar
Case, yep ,still got it. You know we could get flamed talking about such a
car, but bought it new, and reclaimed after 3 Chicago winters with daughter. Very primitive car by today's standards , but a weekly driver for me. Wife drives the C63. Its so perfect it's sometimes boring to me. Motoman
Old 03-30-2013, 09:41 PM
Case1906's Avatar
Motoman-- Let them flame. Pontiac's Ferrari, hold on to it.
Old 03-31-2013, 01:58 PM
motoman's Avatar
Case, holding...it's got steering equal to the C63. That's it. Seems you like variety also.
Quick Reply: OEM Differential Issue--Advice, thoughts??
