C63 AMG (W204) 2008 - 2015
Very Newb Tuning Question (sorry in advance)
Old 05-25-2013, 04:34 PM
Sanders27's Avatar
C63 AMG
So for the personal tuner that comes from Dimsport says to connect the car to a battery stabilizer. Is this sufficient for the context of just flashing the ECU http://www.pepboys.com/product/details/664372/525/ ? If this is not the correct type of item could someone please point me in the correct direction.
Old 05-25-2013, 04:53 PM
bhamg's Avatar
C63 AMG
I can't answer your question but I will tell you not to buy that B&D charger - it is a piece of crap. I bought one for the gf's car and it failed in a week. I have 3 Battery Tenders, two of which are connected 24/7 and still going strong after 10 years.
Old 05-25-2013, 06:04 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
I don't think that's necessary, but I'll also vouch for the Battery Tender brand. Hooked up 24/7 to my Ducati for the past 2.5 yrs.
Old 05-25-2013, 07:34 PM
chrisridebike8's Avatar
'10 C63
I don't use any power source when I reflash mine. I just make sure that I have recently driven long enough to have a full charge on the battery. It takes maybe 2 minutes to do. Someone else chime in and tell me if I'm a moron...
Old 05-25-2013, 07:51 PM
Sanders27's Avatar
C63 AMG
Well that's what I was thinking... But being new to it wasn't quite sure and was just following directions
Old 05-25-2013, 07:58 PM
khaloof's Avatar
2010 C63 AMG
Never used any power stabilizer when flashing my c63.
Old 05-25-2013, 10:23 PM
aussie e55's Avatar
2009 C 63
just make sure your battery has a good amount of charge take it for a 20 min. drive first thats all i do.
Old 05-26-2013, 02:11 AM
SROC276's Avatar
2010 C63 P31 AMG
You won't need it...I have the same dim sport...no issues...just make sure you follow sequence exactly....if you have touch start...remove and use your regular key to go through sequence. The fan will turn on on its own when new map is writing so don't freak out...flashing the car was easier than transferring the files to the flash device for me at least...now takes me 5 minutes to flash without issue. Enjoy
Old 05-28-2013, 01:15 AM
roadtalontsi's Avatar
10 C six trizzle
id unplug the fan while you do the update, it will draw 30-40amps and make the voltage low pretty quick. some of these cars are 08's and the batteries are getting weaker.
Quick Reply: Very Newb Tuning Question (sorry in advance)
