C63 AMG (W204) 2008 - 2015
Rear lower quarter panel & stone chips?
Old 07-09-2013, 03:18 AM
PTW
PTW's Avatar
C63 Coupe
How do you blokes go about rear lower quarter panel protection from stone chips during burnouts/drift/motorkhana etc? I plan on doing some wet & dry motorkhana events and the dry ones can be particularly nasty being held in car parks. My previous WRX STi was hammered across the lower doors and rears and I don't want to go down that path again with such a nice and expensive car.
I've found some removable magnetic sheeting that should work - http://magnet.com.au/magnetic-sheeting-white.html but am open to other suggestions.
Cheers
Old 07-09-2013, 03:37 AM
bhamg's Avatar
C63 AMG
I used this stuff for a long trip through the desert. It worked OK but started peeling at the usual highway speeds after a few hours so I was forced to pull over several times to trim away sections. You can probably find a similar (or better) product where you are.
http://www.buyroadwrap.com/
Quick Reply: Rear lower quarter panel & stone chips?
