Does P31 and 507 also Have 290> Limp Mode?
Lots
Does anyone know if a 2013 or 2014 P31 and/or a 507 will have the dreaded limp mode above the 290 degree oil temp?
Thanks.
Thanks.
Yes, it will begin to pull timing before it reaches 290 then it will go into limp mode for self preservation.
507 SEDAN
I've always been curious. What set's off limp mode?
Is it temperature? Functionality? Brake issue? Engine communication? Anyone have a brief but concise explanation? Or is it just an overall ECU communication that tells the driver enough is enough?
Thanks!
Thanks!
Lots
There was talk about a software update and that the internals being different as having an impact.
Thoughts?
My 2012 C BS is identical in every way to a 2013 C BS. It is a safety and preservation thing that is set, they would not take that out of the tune. If it gets hot its gonna pull timing if it getshotter it will go into limp mode. If the trans gets too hot it will do the same thing.
From what I've been able to gather, the limp mode at the track affects all facelifted C63's with the exception of the BS. The updated software raises the limits slightly, but it just allows the MCT gearbox temps to run a little higher. You can't see the gearbox temps in the C63's (again minus the BS with Perf Media), so you never know when it happens. It's independant to engine oil temps that you see, that's why the engine oil temp numbers for when it triggers is all over the place, just higher than usual.
There's been a few threads of folks retrofitting the BS gearbox oil cooler, that's the only way to solve the issue. The 507's vented hood won't solve the issue. So far, I've heard of 1 instance where the 507 kicked in limp mode at the track.
Was just at Putnam Park this weekend in 507. Ambient temp was about 90 degrees F. With track tires I would go into limp in about 3 hot laps. Oil temp was around 290. The first day when I was using street tires, I did not go into limp mode but did not do more than 3 or 4 hot laps at a time. I destroyed the 2000 mile street tires in about 9 total hot laps divided up into only 3 sessions. I had Tire Rack drop ship new R comp wheels\tires to the track, next morning. The track wheels\tires held up well (no TPMS) but set off the limp in 3 laps. I was really flogging the beast. I raced an E36M3 competitively years ago and used to hold the BMW Club racing B mod lap record at Mid-Ohio for several years so I'm a bit hard on cars, but this was very disappointing. I originally thought it was because Tire Rack did not put in the TPMS sensors, but now I realize it was probably the tranny heat because of the extra stick.
BTW: the car is really fun for a 4000 pound freight train.
1 Post
C63 507, 911 Carrera, Range Rover, Disco
Good to know - wonder if that new cooling package would have let you last longer or eliminate limp mode altogether - at 5k is better in my mind.
My guess is with Ho-Ho's or R1's...likely not if the tranny is what gets hot.
I really don't know what it was, I do know something got too hot.
For 5K, I can get a cheap race car.(kinda, but you get the point) I think this car is a better short burst fun street car. It would be very cost prohibitive to be a GOOD track car.
Or, you can always go to Road America in December.
The cooling package has a larger tranny cooler and a larger engine cooler.
https://mbworld.org/forums/attachmen...7.04.14eng.pdf
Tranny cooler is from BS:
http://www.mbpartsworld.com/p/__/OIL...305001200.html
Engine cooler is from SLS:
http://www.mbpartsworld.com/p/__/OIL...975001600.html
But it's just mounting hardware different from one in BS:
http://www.mbpartsworld.com/p/Merced...975001200.html
Part numbers are here:
THANKS!
The "wheel arch cooler" is the engine oil cooler.
In any case, the massive coolers of this update, for both engine and tranny, and deletion of the annoying fan, make this upgrade very tempting.
'14 C63 507, '11 C300, '96 Cobra, '91 Mr2
Interestingly enough, AMG Performance Media has trans temps in addition to standard oil/water. It's a different head unit, so either tapping in directly to the TCU/ECU as you mentioned through the harness or picking it up on a channel.
Ideally, some company might want to think about picking up these signals and having something along the lines of AEM's serial gauge that you can set threshold values for alerting, peak / hold values, etc...
the transmission control module, which is part of the valve body. The control module has the temp sensor built into it, so yes it directly talks to the sensor.
New to the site and my 507
took it to VIR in Danville Saturday and kept getting the Limp mode. Thought at first is was a traction mode but shut everything off. Now realize it is definitely a temp thing. Very disappointing.
