C63 AMG (W204) 2008 - 2015
Blackening window beading. Advice needed.
Old 11-01-2013, 07:35 PM
GeorgeSmooth's Avatar
C63
I am more or less done with the cosmetics of my car. Looking for a solution to colour the beading that goes around the top of the window into a gloss black.
Is it a big job to remove and have a body shop do it and does it go back on as well as the OEM fitment.
Has anyone done a vinyl wrap and got the finish perfect?
Here is a pic of the car currently. Got the front grill and the beading left and then need to work on the stance slightly.
Old 11-01-2013, 07:54 PM
Kriston's Avatar
C63 AMG
Hi There,
Are you referring to the chrome window trim above the rubber seal? If so, its a very simple Vinyl Job. Most vinyl places will do the whole trim for 100-200 bucks.
If you are somewhat handy, its not hard to do yourself. Or You can have them painted. However, I like the idea of Vinyl as its reversible and a heck of a lot cheaper. Plus you do not have to worry about flaking and peeling after time.
PS: I assume you had the BS kit installed aftermarket. Its an absolute monster buddy. Well done!
Old 11-01-2013, 08:49 PM
avery.whss's Avatar
S550 on order
god damn that BS kit looks UNREAL!!!!!!! I want it
Old 11-02-2013, 12:09 AM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Guys this is a wide body conversion using prior design bodykit.
https://mbworld.org/forums/c63-amg-w...ld-thread.html
OP the chrome window trim is easy to remove and wrap as mentioned above. But man you need facelift taillights and a drop in the front IMO
Old 11-02-2013, 01:01 AM
mr747's Avatar
c63
I love ur car George
Old 11-02-2013, 01:11 AM
Daveskii's Avatar
2013 C350 coupe
I did vinyl and it looks great. If you're in southern california I suggest don Nguyen (sp) to do the work. he has ads on these forums you can reach him at.
Old 11-02-2013, 07:46 PM
C63
I found someone to wrap and will give it as shot. Is there a plug and play solution for the tail lights?
The front must come down but by the looks of things I am going to have to take car of the fender lining first. Its not really sitting as flush as it should and when turning parked it touches on the one side. Recently it also started making contact at 300+ speeds so I gotta take care of that first before moving the wheels closer.
Quick Reply: Blackening window beading. Advice needed.
