C63 AMG (W204) 2008 - 2015
Does mhp headers employ standard gaskets and bolts?
Old 11-15-2013, 01:02 PM
skaarlaj's Avatar
ford svt's, and C63!!!
Like the title says, can you just use the same fasteners that retained the stock manifolds, or do I need to order some header bolts from MHP?
Also, does anyone know if the stock manifolds are sealed to the heads with MLS "multi layered steel" gaskets? If so, I'll re-use the stock gaskets?
Does anyone work on their own vehicles here?
Old 11-15-2013, 01:05 PM
Merc63's Avatar
C63 AMG
Get new mb gaskets and re use your nuts and studs. Might want to grab a few extra nuts and studs though just in case.
Old 11-15-2013, 01:12 PM
skaarlaj's Avatar
Thanks for the reply, are the stock gaskets MLS by chance, and do you know the thread size and pitch of the nuts/studs?
Old 11-15-2013, 09:11 PM
Merc63's Avatar
C63 AMG
Its a multilayer gasket, no clue just grab them from mb dealer, they should have some in stock mine did.
Old 11-16-2013, 11:40 AM
skaarlaj's Avatar
I'll just re-use it if it's multi-layered, and steel. I'm 200 miles away from the nearest dealer. Those MLS gaskets last a long time and have personally reused them numerous times on other cars. Unless they look damaged when removing the stock manifolds.
Old 11-16-2013, 01:45 PM
Merc63's Avatar
C63 AMG
Order in mail.
I wouldn't reuse them
Quick Reply: Does mhp headers employ standard gaskets and bolts?
