Photoshoot:: '08 C63 Estate on ADV.1 TrackFunction ADV15 Wheels
#76
Here's another option...these are rubber like and could possibly stretch over the lock nut?
http://www.colorlugs.com/
#77
Received 3,418 Likes
2012 CLS63
wow Matt, they look great man, congrats!
#79
Nice stance man! Are you on your lowest setting on your H&R's?
I want to try out this set up once my forgestars come in, but don't know if I should go with 265 or 255.
do you think I will rub with a 265/30 19x10 et 48?
#80
I run 275/30 on 10x19 et 48 forgestar and was occasionally rubbing on H&R springs. Now with KW adjusted I don't rub. So you should be fine with 265 if your rubber is not too wide. Some tires have wider sidewall than others.
#81
