C63 AMG (W204) 2008 - 2015
Just install my new setup of wheel but ...
Old 05-03-2014, 02:00 AM
Stefj's Avatar
Mercedes c63 amg
I buy a set of forgestar cf5v and a set of tire Bridgestone re11.
275-30-19 on the rear.
The thing is That my tire hitch inside of my wing. Did you know what should I do ????
First of all is this's normal ? I read a lot of people are already setup like that in the mbworld.
Is this a default from forgestar ? The offset are not mad properly ?
I eard about a way to open the wing a bit with specific tools. I'm afraid of this option.
Please help me with this
Old 05-03-2014, 02:14 AM
socalwdup's Avatar
C63 AMG; Gallardo
what's a wing? my tires are like that too you have to do a burnout and waste like 20% of your tread then it won't hit your fender/rear bumper
Old 05-03-2014, 08:52 AM
Thrilla's Avatar
2014 C63 AMG 507 sedan
More info
We need more information before we can help you out. First of all, what's the size and offset of the forgestars? Are you on stock suspension?
Lastly, I think you meant fender, not wing.
Old 05-03-2014, 10:39 AM
jcfay's Avatar
2018 AMG E63s
Wikipedia - "In British English, the fender is called the wing (this usually only refers to the panels over the front wheel arches, in modern cars, since the rear 'fenders' are more an integral part of the car's body shape)"...
Old 05-03-2014, 10:59 AM
Autosport7's Avatar
C63 AMG
Need to know:
What are the offsets of the wheels?
Are you rubbing in the front or the back?
If front what are the tire sizes in the front?
If rear you may need to drop to a 265 instead if a 275.
If you are dead set on running a 275, then either burn some of the tread of the tire, roll the inner lip on the fenders, or run neg camber in your alignment. Those are your options.
Old 05-03-2014, 12:24 PM
Stefj's Avatar
Mercedes c63 amg
I did with my iPhone
Thank you guys tonight I will log with my computer then I'll send detail and picture
Old 05-03-2014, 02:49 PM
Vise_'s Avatar
2013 C63 AMG, 2013 B250
My guess is the problem is with the tires, RE-11 are extremely square so likely the culprit... I'm running 275/30 on my Forgestar's but they are Michelin PSS so no issues with rubbing.
Quick Reply: Just install my new setup of wheel but ...
