C63 AMG (W204) 2008 - 2015
This is what I did do my car today - AMG Shift knob upgrade
Old 07-17-2014, 11:51 AM
CarHopper's Avatar
E63S | X5
I thought you were going to get rid of the boot and make something similar to the e63 or whatever.
Old 07-17-2014, 12:03 PM
snowmuch's Avatar
C63 AMG
That is coming! I haven't came up with an idea yet!
Old 07-17-2014, 12:04 PM
snowmuch's Avatar
C63 AMG
Originally Posted by olszowa12
This is some serious surgery :O
You need a custom leather boot now - this one is too long.
The boot is perfect because its touching the bottom of the knob, if shorter the rod will be showing
Old 07-17-2014, 12:05 PM
CarHopper's Avatar
E63S | X5
Damnit snow! what am I paying you for?!?!
Kidding, any ideas yet? Also, does it annoy you that when in park it tilts slightly forward and in drive it has it's lean back on? I feel like that would bother me over time.
Old 07-17-2014, 12:07 PM
CarHopper's Avatar
E63S | X5
Matt is referring to how the boot comes up over the base of the knob. Yea, it touches the knob but it still goes up the shaft a little bit.
I feel like some material could be removed from the boot to tighten things up a bit.
Old 07-17-2014, 12:08 PM
Mitch111's Avatar
2009 C63
Looks way better. No?
Yes.
That's some great work, homie..........and an even greater vision for even thinking about it.
Can't say I have, nor would have. That would be a damn lie.
  #32
Autosport7's Avatar
C63 AMG
I am over the shift knob, it looks great, but that wrapped trim is stellar! Dry CF looks soooo much better than the gel coated stuff! I am digging it!
Old 07-17-2014, 12:09 PM
  #33
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
^ That is exactly what I was thinking. It looks weird from the side because of the longer leather boot.
Good job on this mod. I wouldn't do it either since I want to be able to return to stock at anytime
Old 07-17-2014, 12:10 PM
  #34
snowmuch's Avatar
C63 AMG
Not really because when you look at it from driver's seat the AMG crest is actually facing you (maybe a 20 degree angel tilt), and when you place your hand on it it still fits perfectly in your hand.
Old 07-17-2014, 12:13 PM
  #35
snowmuch's Avatar
C63 AMG
To be honest when you look at it from your regular seating position you wont even see the boot! which is a plus! Ill get a shot later today
Old 07-17-2014, 12:14 PM
  #36
snowmuch's Avatar
C63 AMG
Thank you!
  #37
CarHopper's Avatar
E63S | X5
^ Gotchya. Anyway you look at it this is a nice DIY you've started here. I am assuming this will be an ongoing process. Really like how this turned out
Old 07-17-2014, 02:36 PM
  #38
AMGPower88's Avatar
C63 AMG
Wow you got ***** OP, looks good though.
Old 07-19-2014, 01:17 PM
  #39
snowmuch's Avatar
C63 AMG
Here is couple shots from the drivers seat looking down.
Old 07-19-2014, 11:41 PM
  #40
Thrilla's Avatar
2014 C63 AMG 507 sedan
Great job snow! No turning back now.
Old 07-20-2014, 11:30 AM
  #41
snowmuch's Avatar
C63 AMG
I think this can be undone by purchasing the rod assembly unit off eBay.de, probably cost less than $100 if need to be done
Old 03-30-2015, 04:00 PM
  #42
561design's Avatar
2014 VW Touareg, 2012 C63
Snow, did you use anything to affix the shift boot to the underside of the shift knob? I believe the stock shifter has a black collar that holds it up. Is that what you used? Also, the part number I have is 218 260 02 40, is that correct?
Old 03-30-2015, 04:47 PM
  #43
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Wow, great job! I have learned that most all of this car is replaceable by parts, just gotta find the specific part and buy it.
Looks so much better.....But that is true, you could of used a carbon cutting disc and not made so much heat and took less time...
Old 03-30-2015, 05:30 PM
  #44
snowmuch's Avatar
C63 AMG
My knob didn't come with that part. Because the boot is longer, folding the boot inwards will make the connection between the gear knob and boot look OEM
Old 03-30-2015, 05:31 PM
  #45
snowmuch's Avatar
C63 AMG
I just bought a bunch of those for my other projects xD
Old 03-30-2015, 08:55 PM
  #46
561design's Avatar
What part number did you use?
Old 03-30-2015, 10:48 PM
  #47
snowmuch's Avatar
C63 AMG
I can't recall, it was purchased from a vendor on ebay.de.
Old 04-25-2018, 09:32 PM
  #48
S63AMG888's Avatar
MY17 S63AMG - MBUSA Buyback. MY16 SL63 - Sold MY19 W213 E63s. 2020 W213 E63s Wagon
That looks awesome. Got a extra E63 shift knob for sale. Brand new, $450 shipped within the US.
Old 03-04-2019, 10:37 AM
  #49
561design's Avatar
Can anyone confirm if 218 260 00 00 works as well?
Old 03-09-2019, 10:09 PM
  #50
561design's Avatar
Here's my install! As a tip, it's easier to cut down the stem and use a rubber stretch plumber's tape to create a snug fit. As for the boot, when its inverted use the same tape to attach to the stalk firmly and the pull te boot down and install to keep it up under the new shifter.
Quick Reply: This is what I did do my car today - AMG Shift knob upgrade
