Front license plate
I just put my plate half on my workbench and bent it by hand til it matched the mount (when i had that mount). I didnt like the idea of the screws being under that much tension.
I wish I could run around without a front plate. I have the tow hook mount. They won't let you on my military base if you don't have a front plate and your car is registered in VA.
I didn't want to drill holes either. The tow hook was not my cup of tea. I didn't feel right after a few months (still have it). I modified the bracket a little and mounted it lower with stainless ties.
I have raw DIY pics, but never posted.
Xguy (05-06-2020)
That's what I'm thinking of doing, not worried so much about bending the plate, but about the carbon fiber frame that I'm waiting for (in the mail) , I don't want to molest that, supposedly it's made out of strong aluminum wrapped with a CF layer and topped with a clear coat.
I would first Recommend Sto n Sho. I have this for my Lotus. ZERO drilling and it removes in 2 seconds by a cotter pin under the bumper.
https://bigmikesperformanceparts.com/2019-mercedes-amg-c63-sedan-coupe-sns178/
(example only, do not order)
I don't know if they have a model yet for our years, but they will make custom solutions if you give them measurements... I did so with the Lotus and now they have it on their site.
I cut a small V in my aluminum plate where I wanted it to bend.
MY plate finally arrived and so did my CF frames, , I went to a DIY store and got 4 10MM plastic spacers/bushings, (8mm would be the perfect size but I only could find 10) and some screws and went to work here's the results, not perfect but at least sturdy , the rear one on the other hand was simple and straight forward.
doncmleon (05-17-2020)
I just went through my phone and posted a few rear end pictures as you can some of which are before I did anything to the car , it's dark out now but if you need more lower side pictures let me know and I'll take some tomorrow when it's light out
That's not a W204 C63
That's what threw me off
