C63 AMG (W204) 2008 - 2015
H&R DIY?
Old 11-19-2014, 10:09 AM
immelman's Avatar
C63 AMG
H&R DIY?
Anyone have a DIY on the H&R Springs? My main question is about the rear spring? It appears that some of you are removing only the inner lower control arm bolt to replace the spring. Is this correct or do you have to remove the outer bolt, shock bolt, sway bar bolt etc?
Thanks!
Old 11-19-2014, 11:52 AM
Merc63's Avatar
C63 AMG
MB makes a tool to remove the rear spring. It compresses it on the car and you pop it out. I borrowed one when I did it. A regular spring compressor might work/fit as well.
Old 11-19-2014, 12:01 PM
immelman's Avatar
C63 AMG
Thanks Merc, from the info. that I found on the subject it seems that the short cut on this is to remove only the (1) in board bolt on the LCA while having a jack under the arm. Lower the jack, spring pops out, shove new spring in, jack up arm to compress spring and re-install inboard bolt. I'm going to try what I think the process is and see how this works out.
- Mike
Old 11-19-2014, 12:02 PM
Jasonoff's Avatar
Received 1,576 Likes on 929 Posts
2010 C63 AMG
Yes, you can pull the inner control arm bolt and swing it down.
Old 11-19-2014, 12:05 PM
immelman's Avatar
C63 AMG
SWEET!! Thank you sir!!
Car is in pieces as we speak, also doing a LTH install at the same time.. WOW what a pain to get the stock manifolds off...
Old 11-19-2014, 01:38 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Yes that is exactly what you have to do. GL
Old 11-19-2014, 01:51 PM
Ingenieur's Avatar
C63 AMG
what does it look like?
this would save some time
Old 11-19-2014, 02:22 PM
Merc63's Avatar
C63 AMG
I think that method with the Jack and bolt would be faster. This tool is annoying, it has to be positioned perfectly or you can't compress the spring enough to get it out. Or you put it too high on the spring and then the tool binds up when you try to pull the spring.
I'd pull that bolt and use the Jack.
Old 11-19-2014, 03:25 PM
immelman's Avatar
C63 AMG
Thanks Anthony... I wish you had posted your coil overs a week earlier before I had bought my springs.. What kind of car are you going to end up replacing the C with?
Take Care!!
Old 11-20-2014, 01:38 AM
AMG893's Avatar
2010 C63 Estate
This is great info.
So nothing from the top (behind the rear seats) needs to be touched?
Can all be done from underneath?
Old 11-20-2014, 09:34 AM
Jasonoff's Avatar
2010 C63 AMG
Originally Posted by AMG893
This is great info.
Nope
Yup
Old 11-20-2014, 09:56 AM
AMG893's Avatar
2010 C63 Estate
That being the case, are the fronts as easy?
Old 11-20-2014, 10:11 AM
Jasonoff's Avatar
2010 C63 AMG
Easy to pull but the springs are a pain to compress.
This type of compressor is useless. Use the clamp plate type.
Old 11-20-2014, 10:19 AM
AMG893's Avatar
2010 C63 Estate
Ahh, ok.
So for the fronts i will need spring compressors for sure.
cant do like the rear and just drop the same part on the front with the jack underneath it?
Old 11-20-2014, 11:08 AM
Jasonoff's Avatar
2010 C63 AMG
Ahh, ok.
Front is a strut assembly. The spring is under load so you need to compress it to pull the top hat off.
EDIT: top hat not had lol
Old 11-20-2014, 11:15 AM
abcut973's Avatar
^ You'll need a compressor in the front for safely remove the springs in order not to receive it in your face when removing the top hat. And as well to reinstall the top hat on the new springs.
In the back you'll only have to work in the trunk area only if you want to change the shock absorber (in case of coilover install for example).
Old 11-21-2014, 12:57 PM
Thrilla's Avatar
2014 C63 AMG 507 sedan
It looks like the exhaust is removed from Jasonoff's picture. Can this be done without taking the exhaust off?
Old 11-21-2014, 01:13 PM
Jasonoff's Avatar
2010 C63 AMG
Yes, the right side was still in place. Left side was removed to pull the diff.
Old 12-27-2019, 06:06 PM
Martin_S72's Avatar
C300 Sport, C300 Coupe
How long it takes for new springs to settle down after installation ?
Quick Reply: H&R DIY?
