Ground Force GF-6 Wheels offset Question
c63 AMG
Hi guys need help
Will Ground Force GF-6 Wheels 19" with an offsets of ET32 front and ET36* rear would fit on the c63?
We need to know the widths as well
Yeah. No way those work on a C63. The rear isnt even close. You probably need +40 and +50 F/R. Maybe even a little higher on the front. I think the front you listed will definitely stick out a little. The rears will most definitely stick out past the fender.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Correct - with those rim widths you could push the fronts out to about ET35 and the rears to about ET48. The extra 3mm at the front may or may not rub (assuming that you're running a 245 tire), but the extra 1/2" at the rear will certainly mangle up your fenders no matter how skinny you go with the rears (with a 275 and normal camber the tire will hit the fender as you lower it from the hoist).
