C63 AMG (W204) 2008 - 2015
Part Number Request - Front suspension strut bearing
Old 03-18-2015, 08:28 AM
Kriston's Avatar
C63 AMG
Hey Guys,
I need to replace the front strut bearings on my car. A few months after I installed my H&R Coil overs, I started to develop an annoying "clunking" sound over small bumps at low speed.
This is a common issue with H&R Coil overs from what I gather, apparently the front strut bearings prematurely fail due to the design of the H&R Struts.
Either way its a simple fix, I just wanted to verify the part number with you guys.
I think all I need is the below part number, for those who are more part number inclined / tech savvy can you please confirm if this part will work a 2010 C63 sedan. Im going to swap out both sides (only the drivers side is making noise) but I figured since i'm in there I would change both of them.
Appreciate your help.
2049810025
Old 03-18-2015, 03:52 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Looks like it yeah ! GL
Old 03-18-2015, 03:59 PM
Kriston's Avatar
C63 AMG
Thank you!
Same part numbers left and right?
Old 03-18-2015, 04:14 PM
abcut973's Avatar
Originally Posted by Kriston
Thank you!
Correct!
Old 03-18-2015, 10:34 PM
Kriston's Avatar
C63 AMG
Thanks a lot Anthony! Appreciate your help
Old 07-14-2015, 12:43 AM
keithlee21's Avatar
C63
I also have that annoying "clunking" sound. I plan on replacing the strut bearing but I was wondering if it is necessary to replace the upper strut mount. Is that a wear type item?
Old 07-14-2015, 01:43 PM
Testudo's Avatar
C63
I have more of a squeak when turning at low speeds, not really a clunk. I also have the H&R coils. Still think strut bearings are the issue?
Old 07-14-2015, 02:31 PM
Kriston's Avatar
C63 AMG
Upper strut mount bearings are usually the first to go with the H&R Coil overs for some reason.
I would suggest just changing the strut mount bearings (they are in-expensive) however labor costs more then the part itself.
Old 07-15-2015, 09:01 AM
Testudo's Avatar
C63
Thanks. I ordered them. Hopefully the shop won't charge a lot to replace them. I assume I will need to get another alignment after the install?
Old 06-07-2016, 02:39 PM
Jasonoff's Avatar
Received 1,576 Likes on 929 Posts
2010 C63 AMG
Did you ever hear a squeak as well? I get a squeak from Driver Front when I turn the wheel to the left.
Could be the spring seat as well. Haven't pulled it apart yet, just tried cleaning while still on the car.
Quick Reply: Part Number Request - Front suspension strut bearing
