C63 AMG (W204) 2008 - 2015
C63 Coupe window trim removal. HOW TO.
Old 03-28-2015, 12:06 PM
-ian's Avatar
2012 C63 AMG
Ok, after asking yesterday if anybody knew how to remove the lower rear chrome window trim on a coupe and getting no help I decided to give it a go anyway.
Needless to say it's actually incredibly easy.
All you need to do is to ease out the black plastic plug at the forward end of the trim piece. Then slide in a screwdriver and gently pull towards you to release the first clip.
After that using a plastic trim removal tool work your way rearwards easing the trim tool towards you to pop off the remaining clips. There is nothing to break as the trim piece lugs just push into metal grip fittings on the car body.
20 minutes to remove the first side and about 5 mins to do the other once I knew what to do. Off to vinyl wrap them now.
A few photos to show the general idea.
Close up of trim lug
Upper trim removed as well. Not necessary to remove the rear lower piece. I just remov d these as well to make wrapping easier.
View with trim piece removed.
The plastic cap you remove.
Screwdriver used to ease off the first clip
Old 03-28-2015, 12:23 PM
-ian's Avatar
2012 C63 AMG
Job done.
Old 03-28-2015, 01:41 PM
leungsta's Avatar
C63 AMG Coupe, BMW 335xi Frozen Silver
Looks fantastic! So all you needed to do was remove the plug and start unclipping by shoving in a screw driver and pulling ?
Old 03-28-2015, 01:52 PM
-ian's Avatar
2012 C63 AMG
Yep. Use the screwdriver to pop the first clip. Then use a plastic trim removal tool or similar and work your way along to pop the rest off.
I used a screwdriver but anything that will fit in the channel will do. All you are doing is using it as a lever to pop the first clip then you will be able to get the trim tool into the gap between the window and the trim piece to pop the rest of the clips.
Old 03-28-2015, 04:25 PM
w204nyc's Avatar
2017 C63S coupe '09 C63, '15 Durango RT, '14 Jeep SRT8
Just be gentle while you do it. Very easy to bend and break. They're not cheap either
Old 03-28-2015, 04:37 PM
Anatoli's Avatar
E500 estate
Correct!
I think plasti dip is the easier way to go...
I`ll plasti dip my car next month - we will see how it works.
Old 03-28-2015, 05:37 PM
-ian's Avatar
2012 C63 AMG
Originally Posted by Anatoli
Correct!
Sure plasti dip is easier but it doesn't look as good as vinyl. I have never wrapped before and I think the results are pretty good.
I've read all the horror stories about bending trim / breaking clips etc so I was dubious. Anyway it was all fine. Everything came off easily with no drama. Bottom line is to just go steady and you will be fine. Go at it like a bull in a china shop and yes you may break something.
I've plasti dipped my front chrome and star purely because it would be a nightmare to wrap. The wrap looks a lot more OEM. Oh, and overall it was actually quicker to wrap the trim than it would have been to plastidip it.
Old 03-28-2015, 06:41 PM
leungsta's Avatar
Very nice work!
Old 03-28-2015, 07:04 PM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Good work on this. Just went out to the car and did this too. 5min a side. Thanks for reminding me!
Old 03-28-2015, 07:07 PM
JeffDL's Avatar
C63
i left them on the car while wrapping.
C63 Coupe window trim removal. HOW TO.-f6bcc088-3607-4bfc-9440-8b9ef30f58fc_zpshvzei0xm.jpg
Old 03-29-2015, 04:02 PM
Alex-r-1's Avatar
C63AMG Coupe 507, GL X166
I did the same job, just to paint it! And I have a problem with fasteners!
Maybe you can help me ?!
https://mbworld.org/forums/c63-amg-w...ndow-trim.html
Old 03-29-2015, 04:16 PM
-ian's Avatar
2012 C63 AMG
Decided to do the grill as well today. Removed the plasti dipped chrome trim pieces and wrapped with 3M 1080 Matt black vinyl.
Plasti dip v vinyl.
Star was a bit of a pig to remove
Wrapping it was character building stuff.
Not a bad first attempt.
All done
And fitted.
Old 03-29-2015, 05:52 PM
leungsta's Avatar
Was it hard to remove the grill? Great job!
Old 04-25-2015, 02:23 PM
Huchimo01's Avatar
2013 C63 AMG and 2002 Ford Explorer Sport
Hey -ian,
So which brand and thickness of vinyl did you used for the window trim? I am going to do the trim as well as the rear piece above the license plate. I have done a fair amount of plasti-dip on cars, but for the trim I think the vinyl wrap will look much better, and last longer. Plasti-dip has it's place, but in this case I choose the wrap. Nice work by the way.
Thanks,
Howie
Old 04-25-2015, 02:25 PM
Huchimo01's Avatar
Hey -Ian,
So on the grille, what areas did you wrap, and which areas did you dip? I already dipped my grille, but may remove it and wrap it. Just wanted some info from someone who has already done it.
Cheers
Howie
Old 04-25-2015, 02:37 PM
quaalude's Avatar
2012 C63 Coupe P31
Nice write up! I just did this a month ago too. I used 3M GLOSS Black G12 Scotchprint Car Wrap Vinyl Film 1080 Series for the grill and trunk piece and satin black for the window trim. I bought two 5ft x 1ft rolls for $16 each from Amazon. I also got the squeegee tool from there also.
Old 04-25-2015, 03:33 PM
-ian's Avatar
2012 C63 AMG
Lovely looking car. You just need to get your drl covers sorted now. I wrapped mine in cf.
Old 04-25-2015, 03:38 PM
Huchimo01's Avatar
I agree as well. That is a primary area I will be aiming at when I have wrap and tools in-hand. Has anyone removed those DRL surround pieces, and could you share how you removed them? Thanks.
Old 04-25-2015, 03:54 PM
Huchimo01's Avatar
On a similar note, has anyone here covered the front of their AMG with the clear protective wraps on the market as of yet? I just returned from an event yesterday and noticed at least one rock chip that will have me wanting to do some sort of protective covering for the front end. Any input on that from anyone?
Old 04-25-2015, 04:01 PM
-ian's Avatar
2012 C63 AMG
I have removed them. See my guide here.
http://www.mbclub.co.uk/forums/gener...ng-bumper.html
Old 04-25-2015, 04:26 PM
Huchimo01's Avatar
The link is showing up as 'NOT FOUND'...
Old 04-25-2015, 06:07 PM
quaalude's Avatar
2012 C63 Coupe P31
Thanks ian. Your car is looking sharp too bud. I ran out of wrap so I didn't finish the drl covers. Got more wrap but haven't gotten around to covering it yet.
Old 04-25-2015, 06:47 PM
rentzington's Avatar
2010 C63 P30
I may just have to bite the bullet and try to do this one weekend, I plastidipped the borders of my grille and from a distance it looks fine but up close I'm not happy with it.
Old 04-26-2015, 08:04 PM
Huchimo01's Avatar
I finally got it to show up. Looks good. Thanks...
Old 04-26-2015, 08:08 PM
Huchimo01's Avatar
Hey -Ian,
How difficult was it to wrap these DRL covers? I am ordering wrap this week so I can do some of my trim over the weekend. Also what brand of wrap did you use? I just want to do matte black. Did you use any kind of vinyl wrap primer? Thanks.
Howie
Quick Reply: C63 Coupe window trim removal. HOW TO.
