C63 AMG (W204) 2008 - 2015
Looking for a little confirmation before I order suspension...
Old 07-20-2015, 04:26 PM
boosting1bar's Avatar
cars and stuff
After reading more threads than I can remember now lol I'm pretty sure this setup should work without any issues. Getting H&R springs with 10mm spacers front and rear and 17mm spring pads in the rear and keeping stock spring pad up front. Running OEM 19" with 235/35 up front and 255/30 in the rear. I'm going for just flush with the fender and I'd rather err on being inside than outside the fender. I'm sorta stuck between the 10mm and 12mm spacers. I've looked at about a million pics and finally just decided to ask for help haha! Anyone running H&Rs with 12mm spacers? Are you rubbing? Pics?
Actually after even more reading I guess it's 10mm in the rear and 12 in the front.
Old 07-20-2015, 08:24 PM
Former Vendor of MBWorld
VividRacing's Avatar
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
I have seen and sold 12mm all around or 12mm front and 10mm rears. All sit very flush. I have also sold 15mm fronts on 19's
If you can do 12/10, dropped on H&R's and stock wheels, then I think it will get you what you need. No rubbing and looking flush.
Old 07-20-2015, 08:31 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Yes I'm running 12mm front & 10mm rear with oem size tires on my multispokes, flush & no rubbing.
Old 07-20-2015, 10:29 PM
cars and stuff
Yeah I love the look of yours, after I posted I kept reading some and found one of your posts where you talked about it and decided to go that route!
Old 07-20-2015, 10:46 PM
Roswell's Avatar
Thx , do it u won't regret it. My wife prefers that set up over my HRE
Old 07-20-2015, 10:49 PM
Roswell's Avatar
Btw, if u decide to stay oem wheels with spacers & oem tire size, u don't even need the thicker spring pads. The set up will look as good with the oem 13mm pads.
Old 07-20-2015, 11:07 PM
tdotjag's Avatar
2012 C63 w/APX
What if the OP went up to 245's in the front and 265's in the rear? Would this setup still be flush?
Old 07-21-2015, 07:10 AM
Roswell's Avatar
It will be flush but he will most likely rub with 265 & 10mm spacers & lowered.
Old 07-21-2015, 05:01 PM
cars and stuff
In your sig pic is that with the 13 or 17mm pads in the rear? I hate to copy other people's style, but why to reinvent the wheel (lol) when someone has already done it right!
Old 07-21-2015, 05:55 PM
Roswell's Avatar
Thx, yes I'm using the 17mm pads cuz my wheel set-up is aggressive so it helps me avoid/ reduce rubbing.
But on my oem wheels, I sometimes wish the rear was lower.
Old 07-21-2015, 06:47 PM
cars and stuff
Okay great, thanks again so much!
Old 07-21-2015, 07:35 PM
Roswell's Avatar
No prob, here an old pic to show u the height front & rear...
Looking for a little confirmation before I order suspension...-dsc_0136_zps2d181dcd.jpg
Old 07-22-2015, 11:03 AM
Dazzagt's Avatar
C63 AMG - PP+
H&R springs, 12mm H&R spacers all round stock with 19's Multispokes, OEM spring pads, no rubbing at all. Looks tight / very flush and 265 width Conti's on the rears.
Old 07-22-2015, 11:38 AM
Dazzagt's Avatar
C63 AMG - PP+
Looking for a little confirmation before I order suspension...-img_1749_zpsff1e6214.jpg
Excuse the used look, was back in Jan after coming back from having springs fitted
Looking for a little confirmation before I order suspension...-img_1751_zps09f78de9.jpg
Sits perfect, and no rubbing even when pushing on.
Old 07-22-2015, 04:04 PM
cars and stuff
Thanks a lot for the pics!
Quick Reply: Looking for a little confirmation before I order suspension...
