Anymore info on this N/A Beast??
Just curious how many miles do you have on your engine? Nice runs man!
Yeah I will try again early next month. Colder the weather the better. What tire pressure do you run in the rear? I had it at 42.
Received 2,842 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I get my best 60' on street tires at about 26psi cold. Low 1.8x's all day. 42? Well there's your problem.
#32
if you have problems launching use comfort mode, hold the revs to 1400-1500rpm and make sure u dont hit the kickdown under the pedal. once u out the hole change to M on the fly to hold the revs higher. using comfort mode allows you to launch using 2nd gear this way you wont spin and eliminate a shift.
#33
42s way to high and thats way to high for daily driving also. i keep mine at 35-36 for DD and when i use DRs i do 18psi cold and work with that. but i have my tires screwed to the rim so they dont spin at that low pressure but that will get u best 60 foots.
#35
#37
#38
MHP v3 tune long tube headers with cat delete the 180 thermostat row boxes with BMC filters gruppe m carbon front intake H&R springs and stock 18s with 285/35 nitto 555 drags the car is an 08 without the performance pack and I have a wave track LSD on the way
#40
