C63 AMG (W204) 2008 - 2015
Replacing/upgrading front HK speakers
Old 10-14-2015, 07:57 AM
Phorte's Avatar
2015 C63S
Hi all,
I've got option 810 Harman Kardon sound system and both the centre and front left speakers are failing (typical split-cone rattling sound).
I quite like the stock system (especially being a hatch, I get decent bass). What are my options for replacing my entire front stage (left, right and centre speakers + tweeters) WITHOUT changing anything else (amps, wiring, etc)?
  • Am I limited to only replacing with the same HK speakers?
  • Or, can I replace with aftermarket/higher quality speakers whilst still running off the existing wiring/etc?
From searching/research, the only threads I've found are from people upgrading everything including amps, etc which I do NOT want to do.
Thanks in advance,
Linh
Old 10-14-2015, 01:45 PM
Durban's Avatar
C63, S55, 190E 16V, S600 Maybach, S550, GL550
Im no audio expert but heres what I think.
The only way to change your speakers is to redo the entire system. Is has something to do with fiber optics.
Again I'm not positive on this. I only say it because when I tried to replace the speakers on my S55 I just ended up doing the stock speakers because I had to replace the whole system if I didn't.
I honestly dont think the HK speakers need to be upgraded though. They perform pretty well. If they are crackling because of bass then I would suggest getting a sub and then have the ability to turn down the bass on the car speakers and still have the bass from the sub to make up for it. Thats what I ended up doing in the S55 and it worked out really well.
Old 10-15-2015, 09:30 PM
Phorte's Avatar
2015 C63S
thanks for the input managed to find a local guy stripping out his 507. will just be swapping in OEM replacement of the broken speaker(s).
Old 10-16-2015, 08:20 AM
yellows2k's Avatar
what else was teh guy stripping in the 507
Old 10-16-2015, 05:15 PM
Phorte's Avatar
2015 C63S
everything apparently. he posted it up on FB but hasn't really been updating it with what's left/sold.
he's in brisbane. I'll PM you the details.
Quick Reply: Replacing/upgrading front HK speakers
