C63 AMG (W204) 2008 - 2015
Smoke from oil fill location
Old 10-22-2015, 09:15 PM
gforc3's Avatar
C63 Coupe
Checked the oil today and noticed it was a bit low, so I opened the oil fill cap to add a quart and there was a bit of smoke coming out. Not a lot but enough for me to notice. Anyway my question is this normal? I've never seen anything like this before so unsure what to make of it
Old 10-23-2015, 06:35 AM
odonnks's Avatar
Ford Truck, 2014 C63 AMG 507
I'm assuming the engine was warmed up. If so i'd consider this normal.
No smoke but hot oil vapor.
Old 10-23-2015, 10:35 AM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
^ This. It's indeed likely to be vapour - although it is generally moisture and other combustion by-products, not the actual oil that vaporizes (the boiling point of motor oil is well above 500 F - it would ignite well before it turns into vapour). It's perfectly normal.
Quick Reply: Smoke from oil fill location
