Window problem
Window problem
So today my passenger side window stopped going up automatically? I have to hold the button for it to go up and when it's up all the way and let go of the button, it comes down a little bit and then when I put it up again it goes all the way up. It's not a big deal but it's very irritating, anyway we can reset it instead of taking it to the dealer?
I think you can reset the adaptation for the window by pushing and holding the down button until window comes all the way down but dont let go for about 10 sec then roll the window up and hold the button for ten seconds
Yes what they said above will fix it. Some searching around will give some different descriptions on how to do it. Mine does this every winter a few times. It's supposed to be a safeguard for when it detects resistance (happens a lot when it's cold or icy). First time I took it to the dealer and they said they see these all the time. Takes 10 secs and my service advisor did it and sent me on.
In the operator's manual.
Resetting the side windows.
You must reset each window if a side window can no longer be closed fully.
>Close all the doors.
>Smartkey to position 1 or 2.
>Pull the switch on the driver's door until the window is completely closed.
>Hold the switch for an additional second.
if the window opens again slightly
>Immediately pull the switch until the window is completely closed.
if the window remains closed after the button is released, the window has been reset correctly.
if this is not the case, repeat the steps again.
