C63 AMG (W204) 2008 - 2015
Would you put used tires back on?
Old 03-26-2016, 03:58 PM
Dogtag114's Avatar
2009 c63
So my front PSS worn out to the belt on the inside like many... I have two choices:
1. Put the new PSS back on sitting in my garage.
2. Put on a pair of Pzeros I've had sitting in my garage from when I switched to PSS and was overly pure to switch all four. They still have 7/16 across.
3. Bonus choice... Someone wants to buy the pzeros real cheap...
Old 03-26-2016, 04:13 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Are you going through a divorce and bankruptcy--if so go with the used tires--that will also help in child care review!!
Old 03-26-2016, 04:32 PM
AMG3.2's Avatar
C63 AMG, P30
I see absolutely no reason not to go with re-installing the P Zero's.
Old 03-26-2016, 07:35 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
ya I would use the pzeros first. front tires last very long. ... at least for me
Old 03-26-2016, 09:53 PM
Dogtag114's Avatar
2009 c63
Option 4... Put the new tires on since I have them, save the pzeros for the next go around which will be on a very used car by then...
Old 03-27-2016, 02:22 AM
Phil Chow's Avatar
W204 C63
I'd sell the PZeros, and use the PSS.
I just don't like PZeros when I've used them.
Old 03-27-2016, 08:57 AM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
Strange these most obvious criteria did not yet get mentioned:
1. Do not mix different tires (e.g. Pirelli and Michelin) on a car
2. Discard tires older than 5 years
3. If above criteria are met, reuse, if they have enough tread left.
Old 03-27-2016, 10:26 AM
Dogtag114's Avatar
2009 c63
1. I understand "do not mix" but I think it refers to types of tires... Ie both "summer performance" is ok... Maybe if your tracking it and pushing edges... Then I might buy the do not mix brands argument...
I think they are two years old...
Where is best place to sell these? eBay? Craig's? I really don't want to deal with the bother of strangers coming buy to look at them...
Old 03-27-2016, 10:33 AM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Use up whatever tires you have. If you're not tracking the car it doesn't matter.
Old 03-27-2016, 11:19 AM
AMG3.2's Avatar
C63 AMG, P30
Exactly -- to and from a workplace / grocery getter is hardly a reason to go even care about mixing a tire like a P-zero and PSS.
That being said, if you had you had Bridgestone RE-71R's in the front and Continental DWS in the rear, I'd be giving you other advise as the characteristics of those tires are VERY different and could lead to some strange handling characteristics of the car.
Between P-Zero's and PSS for street use, I'm willing to bet 9/10 wouldn't be able to tell.
Old 03-27-2016, 12:13 PM
Wobble64's Avatar
Only in America, LOL. In Germany, Austria or Italy nobody would even consider mixing different tires front and rear on a car like ours.
And I tossed my Yokohama fronts when I went to PSC2s, even though they still had 50%. But I can believe that most folks here will not notice if they just drive their car slowly. But then, why drive a C63? :-)
However, my experience regarding selling is also it is too much hassle to be worth it for used tires. Unless maybe locally via Craig's list and pickup.
Old 03-27-2016, 12:25 PM
Jasonoff's Avatar
Received 1,576 Likes on 929 Posts
2010 C63 AMG
Even if for track use. If any difference at all, it's only going to understeer or oversteer more than a freshly matched set given they're in the same performance category. The mis matched tires are not going to have a disagreement and magically disintegrate.
Rubber compound degrades during heat cycles. Leaving on old matched fronts with fresh matched rears is essentially the same thing.
Old 03-27-2016, 10:38 PM
jordanaf's Avatar
507 SEDAN
yes, i would put the PZeros back on
Old 03-28-2016, 09:42 AM
Wobble64's Avatar
btw, what kind of PZeros are we even talking here? PZeros go from an all season tire all the way to Trofeo Rs. Depending on that they may harmonize reasonably with the PSSes or not.
Old 03-28-2016, 11:59 AM
agentMurdoc's Avatar
I'd throw the P-zero on there. Unless the new PSS in your garage are aging, I would put those on. Would suck to have brand new tires that you shouldn't use because they sat too long.
Easiest place to sell is Craigslist, IMO. You could do eBay, but I just hate the hassle of shipping them. Especially with the possibility of incorrect shipping quotes and junk. Not to mention eBay and Paypal's ridiculous fees.
Old 03-28-2016, 12:01 PM
AMG3.2's Avatar
C63 AMG, P30
Sorry -- but what does this mean?
Old 03-28-2016, 01:15 PM
Dogtag114's Avatar
2009 c63
Originally Posted by agentMurdoc
...Would suck to have brand new tires that you shouldn't use because they sat too long...
hmmm... interesting... the old PZeros are 4-5 yrs old... and I don't want the hassle of returning the new ones... and didn't think about the new ones getting 4 yrs old before I put them on...
In hindsight, I wish I just threw the PZeros on, but given where I am now... I think I'll throw the new ones on.
Thanks all.
Old 03-28-2016, 02:03 PM
Wobble64's Avatar
Sorry for not having been clear: If the PZeros in question are PZero All Season tires, they would be very different from the PSSes and hence the car would handle poorly. If the Pzeros in question are for example, PZero Rossos, then they would be much more close in properties to the PSSes, hence the car would handle in a more balanced way (without excessive over- or understeer).
Old 03-28-2016, 02:24 PM
AMG3.2's Avatar
C63 AMG, P30
Oh yeah 100% correct.
Old 03-28-2016, 03:38 PM
Arjy's Avatar
2020 AMG C63 Coupe, 2012 C63 AMG Coupe, 1989 560SL
I would think they are the PZeros that were OEM on some 08/09 cars but maybe TC can specify
Old 03-30-2016, 09:13 AM
I am Jeff's Avatar
Steel Grey Metallic C63!!
My recommendation would be to use up the old Pzeros that you have in your garage. Pzero's rears don't last very long. They can be used up even quicker if you want to make a youtube burnout video. lolz Then switch to your new PSS's in your garage.
Quick Reply: Would you put used tires back on?
