H&R Springs and Spacers
i will be picking up a 2011 sedan later this week, and i have already ordered springs for it. I would like to know what size spacers i can fit for the front and rear to give it that slightly wider stances also can i use the 17mm spacer pad as well?. I will running on the stock wheels for a little bit till i decide on what wheels i would like to put on
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
congratulations on the new ride! goodluck and enjoy!
OEM lug bolts are 27mm shaft length. Watch the length on the rear or the bolt tip will hit the parking brake springs. You can go a little longer on the front.
I'm on H&R springs with 13mm rear spring pads.
Also running spacers front and rear
Spacers specs:
15mm front
12mm rear
Car sits so flush it's perfect. Zero rub.
I'm running the OEM 5 spoke wheels.
Spacers specs:
15mm front
12mm rear
gr33dy nerd (04-06-2016)
