C63 AMG (W204) 2008 - 2015
Order New Pads and Stainless Lines
Old 04-07-2016, 06:56 PM
AMG6.3's Avatar
C63
I just turned 42,500 miles on my car and my front and rear pads need to be replaced.
I decided to go with the following:
- Porterfield RS4 pads
- Stainless Brake Lines
- Motul Rbf 600 fluid
I can't wait to get rid the OEM pads due to brake dust and to see how above works.
Old 04-07-2016, 07:08 PM
SaphGreyC63's Avatar
2012 C63 AMG Sedan
This it the first time you're changing pads?!
Rotors still good?
Old 04-07-2016, 07:52 PM
AMG6.3's Avatar
C63
Yes, first time changing pads, I mostly downshift to hear exhaust rather than braking much for fun. Rotors should be fine with 40K.
Old 04-07-2016, 11:15 PM
AMG3.2's Avatar
C63 AMG, P30
That's a nice little upgrade right there.
I plan to go with Endless MX72 and Stainless Lines when the time comes. Not sure about fluid though - Motul may also fit the bill when the time comes.
Old 04-08-2016, 12:33 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
The Endless MX72 are an excellent choice if you want a street-friendly pad that can also withstand weekend track warrior (ab)use. If the OP got 42K+ miles out of a set of pads (), the Porterfields are a better choice for him.
And, I'd definitley stick with the OEM MB DOT4+ brake fluid even if you end up flushing it 4x as often. The viscosity of the RBF is easily 2x greater that of the MB fluid (and gets even thicker at colder temperatures), and the ABS pump is a lot more expensive to replace than flushing your brake fluid twice a year (if you track your car every other weekend that is) instead of every two years.
P.S. As for the S/S braided brake lines... the MB ones are already braided, under the protective rubber. Zero flexing and no worries about the hose popping out of the fittings or oxidation, plus they're DOT legal. I have S/S lines on all of my other cars - but when I saw a nicked E63 brake line and how it was made, I decided to leave well enough alone. There's no point in upgrading something (and calling aftermerket S/S lines an "upgrade" in this particular case would be debatable at best) that is already able to withstand more abuse that what you can possibly throw at it even with heavy track (ab)use.
Quick Reply: Order New Pads and Stainless Lines
