tire Q
The 255 35 19 tire is too tall for a C63 unless you have a personal reason for running it.
The OEM size is 255 30 19 and is the size I would recommend. If you want to go oversize on OEM rear wheels you can run a 265 30 19 or 275 30 19 and although the 275 is getting a bit too wide for the wheel width of 9"it will work.
You have the wrong wheel diameter. In 18" the OEM rear tire size is 255 35 18. In 19" the OEM rear tire size is 255 30 19.
Received 2,845 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
This could go on for awhile.... https://mbworld.org/forums/c63-amg-w...ove-grill.html
