C63 LED light bar.....(yeah, I know)
So, I already know that for a lot of you guys this will be a vomit inducing venture BUT I happen to not only DD my Benz but also drive to work around 4am through 20mi of the most desolate/deer infested back country roads in the continental United States so the more light I have in front of me the better, period. (hell, what i should have done was put on an expedition style roof rack with a 52" LED light bar and called it a day!!!)
...but anyway.....
I test and review lots of LED and HID products for numerous manufacturers so I have a pretty good knowledge base about what is good and what is not. With that being said I recently tested a new light bar setup with the new 5D fisheye lenses and was VERY impressed with the output and quality so I decided I'd throw it in the Merc...
22" LED Light Bar was a PERFECT fit for the lower center grill. Yes, there is a cooler behind it that needs airflow BUT there is plenty of room around the Light Bar with it installed as there is a deflector/diverter at the bottom of the grill that directs incoming air up and through the lower cooler(I drive pretty hard a lot of the times and even with the still 95* days i have seen ZERO increase in temp)
the only thing that i needed that was not included with this particular kit were some small L brackets so that i could mount them to the front aluminum support and then hang the light bar vertically down from them, easy as pie. For the record there is PLENTY of room behind the lower grill even though it doesnt look like it. The center of the light bar is roughly 4" behind the center of the grill and the sides are roughly 2" from the outsides of the grill.
...also, i did not use the switch that came with the AWESOME relay harness for the light bar, instead I cut off the switch itself and tapped the relay harness trigger feed into the headlight hi-beam feed. That way i can NOT turn on the light bar individually(by accident or on purpose) but the light bar comes on with the hi-beams
...but anyway.....
Jag F-Type V8
Sure it does not look great there, but it really isn't "that" noticeable. Anyways, from someone who also drives on dark roads early in the morning (alligator alley here in FL), I can COMPLETELY understand why you did this. Hopefully you have no voltage issues. Nice work.
...no voltage issues as I run OPT7 LED hi-beams already so the combined draw of the OPT7s and the light bar is still less than the factory halogen high beams were.
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Wait.... you put a light covering up your transmission cooler and radiator?
You may not see an increase now, but that's a very bad idea with how these cars handle heat. I'd reconsider the placement or get rid of it altogether. The scoop top at the bottom of the center opening is not going to do much as it actually forms part of the scoop for the main oil cooler. I know you need more light, and it certainly looks like you got a lot more, but I'd think you need a thermally-healthy cooling system more - that light is directly in front of the trans cooler. There has to be a less-obtrusive way to achieve what you're looking for.
Have you looked into upgrading the fogs, or turning them into auxiliary high beams? I'd think you could put massively bright lights in those openings, retaining the factory look and cooling system effectiveness.
Mazspeed (10-15-2016)
I would be worried about the amount of airflow you just removed - like 40% of the area is now covered - probably ok in the cooler months, but would be a bit worried in the summer for sure in stop and go traffic or during spirited driving.
been thinking a little bit more and id be willing to bet that an intercooler would actually interfere more with the trans cooler than the light does....couple the slowing down of the air while it travels through the fins PLUS the added heat coming off of the intercooler and it would HAVE to be more....but either way, im good with it
This is absolutely NOT a flame, but are you being serious or goofing??? Not only do they not work at all in repelling deer but have actually been shown to ATTRACT deer....I haven't even seen them in years
Man. Tough crowd. I think for what you are using the car for, it's a good mod. Seems like you rarely encounter traffic and have long open runs where you have good air flow. And the added safety will help keep the car running rather than in the shop for a deer impact. And you don't track the car. Although I do wonder if there is a way to mount a light bar inside the top of the windshield instead, kind of like police lights (I know those are thinner and usually only one row of LEDs).
Cls350 came stock with F 245 and R 275.
Hmm. My mother (from whom I apparently inherited my lead foot) has the whistles on her SUV, in Indiana deer country, they've been very effective for her, and I've seen it first hand. They absolutely do not attract deer. But I'm certainly no expert on deer whistles, lol, and I guess it depends on what whistle is used.
i know the "Alley" well....I am used to seeing blue eyes light up on the side of the road, but when you see orange you know youre in trouble!!!
http://www.opt-7.com/fluxbeam-led-headlights/
Are these the OPT7s you use? If so I just have a couple of quick questions, as I'm interested in converting to those from my current HIDs.
