CL-Class (W215) 2000-2006: CL 500, CL 600
CL500 TRUNK!!!!
Old 02-24-2013, 05:22 PM
MiguelsC2CL's Avatar
2002 CL 500
When I purchased my CL. I was a bit disappointed it didn't have every option ie:auto trunk close,distronic,park assist. None of which I would use anyway.
Now it's obvious they are things I won't have to fix either.
Old 03-02-2013, 03:38 PM
eviz71's Avatar
2003 CL600
awiner,
Can you tell me where to get the Pump Actuator for my trunk?
Old 03-02-2013, 07:14 PM
Super Moderator
awiner's Avatar
2003 CL55 AMG
Originally Posted by eviz71
awiner,
Is this what your looking for?
http://www.cart.com.au/mono-global/view/2606/93594562/
Old 03-03-2013, 10:58 AM
eviz71's Avatar
2003 CL600
Pump Actuator
Thanks awiner,
Old 10-10-2013, 09:40 PM
jdrs's Avatar
2006 CL500
Thanks for all your information. It has been quite helpful. Could you tell me how to remove the locking rod. I believe it should pop off the ball joint but I am afraid I might damage something. Would rather know what I am doing. Thanks again, John
Old 10-10-2013, 10:33 PM
Ghost25's Avatar
07 RClass ,01 CL500
Glad you were able to fix the issue.. I just fixed mine as well, my son crack a vacumm hose on my rear seat kicking it and leak kept shutting pump off, quick fix all good now.
Old 11-03-2014, 08:05 PM
  #32
Gottayachta's Avatar
S600
S600 trunk problem
I have just replaced the vacuum pump that activates door closures, door locks and lumbar bags ect. The old one had over heated and failed.
After replacing the vacuum pump, all the above functions work normally. But when I try to open the trunk, the trunk does unlock, but lift pump does not come on. The indicator light on inside trunk button does not come on.
Does anyone no what the problem might be?
Old 11-04-2014, 09:26 PM
  #33
Super Moderator
awiner's Avatar
2003 CL55 AMG
Check your hydraulic pump under the battery. I bet it needs fluid.
Old 02-13-2016, 10:24 PM
  #34
LynnBilodeau's Avatar
SL55, Opel GT, 70 LT-1, BMW 745 turbo, MRoadster, 49 Stude truck, 69 Z/28, Ferrari project
Digging up an old thread. What kind of fluid does the trunk closer take?
ATF? Pentosin?
Old 02-14-2016, 04:14 AM
  #35
tusabes's Avatar
Mercedes
Either will work
Pentosin is higher quality synthetic , if you already have some use it
Otherwise no need to Spend on pentosin if you already have atf handy
Old 02-14-2016, 03:41 PM
  #36
So, got the pump off, but don't see any way to add fluid other than removing the reservoir, fill it up and put it back on.
Old 02-14-2016, 04:23 PM
  #37
Well, there may be another way but that worked for me.
Old 02-15-2016, 05:07 AM
  #38
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
i didnt even know that there is a hydraulic pump under the battery in the trunk. Wow.
Old 02-15-2016, 06:40 AM
  #39
tusabes's Avatar
Mercedes
Only if you have the power opening and closing trunk lid
Not all cl500 have it, some just have a trunk opener
Old 02-15-2016, 09:59 AM
  #40
I have a friend with a CL500 with the power trunk. His is acting up just like Sherri's was.
I have invited them over to the house (they haven't seen our new place yet) and offered to fix the trunk issue. If they take us up on it, I will take pics this time. Very easy fix. Hardest part was getting that mongo sized battery out of there. Awkward angle.
Quick Reply: CL500 TRUNK!!!!
